Dura Ceramic - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-03-2007, 12:33 PM   #16
We have applied this product in our kitchen w/grout. We are very happy and are planning on doing the bathroom next.
About the grout smearing, it will smear, even after set, if cleaned with an ammonia product.
sewpie is offline   Reply With Quote
Old 07-04-2007, 10:28 AM   #17
Rewards Points: 1,488
Originally Posted by jproffer View Post
Zel,
The purpose of the cement board is to "decouple" the tile from the plywood...that's all..nothing more.
Please explain this one to me. How is it decoupling the tile from the plywood when the tile is bonded to the backer board with thinset, and the backer board is bonded to the plywood with screws AND thinset?
The logic defies me.
Contrary to popular belief, it's not meant as a "flex stopper". You should have the floor within flex tolerances before the rock is installed.
On this we will definitely agree.
In my opinion, using a 1/4", 3/8", or even a 1/2" backer board over a single 3/4 plywood subfloor is a sure way to have to much flex (depending on the floor span of course), which will can cause the grout cracking issues.
ktkelly is offline   Reply With Quote
Old 08-01-2007, 04:29 PM   #18
Thumbs down
problems with DuraCeramic
I had Congoleum Duraceramic professionally installed in 2004 - I love the look and the feel. But after only one year, the tiles began to get little holes all over the surface! Has anyone had a problem like this? What started as maybe a dozen holes is now more than 75! After more than a year of calling, waiting, and inspectors coming and going, Congoleum decided I must have made the holes myself and refuses to stand behind their warranty. They claim no one else has had this problem, is there anyone out there who has? At this point, I would never recommend duraceramic to anyone any more! As for the epoxy grout, it was a mess and took the installers three trips to get it right. Then I still had to clean it off my tiles on my hands and knees with a scrubber, but it has never cracked or stained.
lesneb is offline   Reply With Quote
Old 03-02-2009, 05:54 PM   #19
Duraceramic tile is NOT durable
Do not buy this product and do not be taken in by Congoleum's so-called lifetime warranty. We are two adults who wear slippers in the house. No pets. No children. After less than a year, there are spots on our Duraceramic kitchen floor where the surface has come off. I bought this product because of Congoleum's lifetime "will not wear out" warranty, but Congoleum says the damage to my floor is not covered by the warranty. In fact, they suggested that we had caused the damage by dropping or dragging heavy objects across it. All we have done is walk on it for less than a year.
lknecht is offline   Reply With Quote
Old 03-02-2009, 07:24 PM   #20
ccarlisle's Avatar
If you get into a shouting match with a flooring company, look up "Independent Floor Inspectors" in the YP. they're out there and this is what they do. They give independent analyses of flooring problems and their cause. May be worth $250 to have one in...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-03-2009, 11:43 AM   #21
Floorwizard's Avatar
Yea, instead of pasting crap about Duraceramic which has never been a problem for me since the beginning, perhaps you should get another inspector.
I have to tell people their lam damage is because of moisture and quite often they say "I never spill anything on it!"
Regardless - it's water damage. It's obvious.
I would assume the duraceramic inspector thought your damage was obvious too.
If you think otherwise....prove them wrong with your own inspector.
Floorwizard is offline   Reply With Quote
Congoleum Dura Ceramic Bonnie Flooring 31 01-28-2011 06:38 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 09:45 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 07:56 PM
