Dura Ceramic - Flooring - DIY Chatroom Home Improvement Forum
Old 07-14-2006, 09:52 PM   #1
dura ceramic
I thinking about purchasing dura ceramic. It looks better with grout but the store installers tell me that grout is a problem. It will either crack or discolor. Have any of you had any dealing with this product.
sparky9999 is offline   Reply With Quote
Old 07-16-2006, 07:18 PM   #2
pro flooring installer
Send a message via AIM to floorman Send a message via Yahoo to floorman
in my opinion this stuff is junk and would direct you to real tile.This is someones attempt to get to the cheaper side side of the ceramic market and try to sell you somwething that is going to fail you in a year or 2 .If you are going to spend this money on tilelike products spend a lil mo money and go witrh tile
floorman is offline   Reply With Quote
Old 07-16-2006, 08:32 PM   #3
Angry
ceramic tile substrate
Floorman, I had ceramic tile put down in my kitchen and the regular grout is cracking all over the place. The cement board is 1/8 inch thick, but maybe there weren't enough screws put in. I was wondering if take up the tile and put in more screws (I read where screws shouldn't go into joists, is this true? or do screws weaken the joists too much?). Would more screws firm up the floor, which is over a basement. Is there anything else that I could do, like use a rubbarized grout that bends without cracking, or a fiber glass mesh that stiffens when cemented between the tile and cement board? What should I use for the adhesive between the tile and cement board? Mastic stuff was used before, but there are a lot of cracks, say 50% of the tile where we walk.
metamel is offline   Reply With Quote
Old 07-16-2006, 08:37 PM   #4
The first questions i would ask is what thickness is the subfloor?And what type is it?(particle board,osb,plywood)Then what size are the joists and the spacing?Lets answer those first and then we can proceed with how fix the problem.
Old 07-17-2006, 09:33 PM   #5
The Joists are 16 inch over center, and are probably 2 x10s with 3/4-inch plywood over the top. The joists are 12 to 14 feet long with no support posts during that span. The cement board is 1/4-inch thick.
Old 07-17-2006, 09:40 PM   #6
Maybe this Ditra product is something to consider for my floor with the tile grout cracks. Have you had success with this product or something similiar?
Old 07-17-2006, 11:05 PM   #7
Floorwizard's Avatar
Duraceramic has performed on all jobs for months now. if installed correctly, there should be no more problems than that of a tile.
Duraceramic is alot more affordable, and not all clients are ceramic clients.
It is definately not in the ceramic category as far as value and durability, but it is also far away from the "Junk" category as well.
Floorwizard is offline   Reply With Quote
Old 11-28-2006, 04:40 PM   #8
Sparky9999 did you put down the DuraCeramic?
i heard the same thing about the grout but that it smears. Well, i had it put down and it does smear. the contractors didn't wipe it up so now i have to do it.
From what i have heard th grout is supposed to be more stain resistant because it is acrylic and Congoleum has a warranty against staining.
i was torn between ceramic and this Dura Ceramic more for pratical reasons than money. I hated the idea of the permanance of the subfloor and the hardness of the ceramic.
So far i like the look but i need to get up the smear. My contractors were terrible. I have had them back several times for glaring mistakes...I should have let me husband do it himself but I was impatient.
cmanley is offline   Reply With Quote
Old 11-28-2006, 08:08 PM   #9
DIY'er
Rewards Points: 150
In your kitchen where the grout is cracking was the cementboard screwed AND thinsetted to the subfloor? It should be.
Doug Russell
"What if the hokey pokey really IS what its all about."
dougrus is offline   Reply With Quote
Old 04-16-2007, 12:52 AM   #10
Exclamation
Need Help Asap!!!!
Has anyone gotten sick when installing dura ceramic??? Particularly with the ds100 duraset glue???
My husband has been installing carpet/lino for 20 years, installed the tile for the 2nd time and got dangeriously ill!!! Felt dizzy and then experienced a Grand Mal like seizure ( was not a grand mal though). He had these sympotms for 48 hours.
If anyone has any info or has become ill when installing this product please email me.... I can really use some help!!!
installer1 is offline   Reply With Quote
Old 04-16-2007, 12:14 PM   #11
I have not heard of the illness at all.
So far no complaints....
Old 04-16-2007, 05:02 PM   #12
zel
Rewards Points: 150
Send a message via AIM to zel
Up above, I seen someone mention 1/8" and 1/4" thick cement board. I didnt even know they made it that thin, and I would think neither is a good choice for floors, maybe only walls. IMO
When we did the bathroom recently, we used backer board screws every 8" to start, then added more as needed, in the joists and wherever there seemed to be some play. We also thinsetted all the seems and edges.
zel is offline   Reply With Quote
Old 04-16-2007, 06:10 PM   #13
jproffer's Avatar
Rewards Points: 706
Zel,
The cement board screws should NOT be into the joists, if it's at all possible to avoid them.
And hopefully you thinsetted under the entire sheet, not just the edges and seams.
1/4" Rock works fine for floors and (although I've never even heard of) 1/8", it would be OK too. The purpose of the cement board is to "decouple" the tile from the plywood...that's all..nothing more. Contrary to popular belief, it's not meant as a "flex stopper". You should have the floor within flex tolerances before the rock is installed.
jproffer is offline   Reply With Quote
Old 04-16-2007, 08:19 PM   #14
zel
Rewards Points: 150
This is the first tile project I've ever been involved in. My Dad was a carpenter for many years and he was the "foreman" on my project. He said he has always done it that way, screwed to the joists, not thinsetted, except for the seams and edges, and he has never had a problem. I'm not saying what is right or wrong, but he is extremely meticulous and I trust his opinion. The tile work he has done in his parents house and his is still looking good after 20-30 years. JProffer, I respect and value your opinion and will keep it in mind when I do the other bathroom floor.
Old 04-18-2007, 07:22 PM   #15
You NEED thinset under the boards and NEVER screw them into the joists, he's been very lucky up until now, that's all, use Ditra, alot easier to install and faster, better product as well.
R&D Tile is offline   Reply With Quote
Congoleum Dura Ceramic Bonnie Flooring 31 01-28-2011 07:38 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 10:45 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 08:56 PM
