Drylok Over A Concrete Slab? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 11:19 PM   #1
Drylok over a concrete slab?
I am getting ready to put down laminated flooring over a mish mash of concrete slabs in my studio apartment. I am going to use the manufacture recommended plastic underlayment but wanted to seal the slab first to help keep the moisture vapor at bay.
I was thinking of using Drylok but am a little worried that it is not going to stick to some portions of the slab. I have ground all the old paint off of these areas but water still beads up on top of the slab in fact no amount of grinding seems to make the slab let water in. I assume that it was sealed at some time in the past.
Am I worried for no reason or is this going to be a problem? Is there an etch I can use to make this work? Should I be using a different product for this application? Was thinking of a potassium silicate product but the guy at the local concrete specialty shop told me that after using potassium silicate nothing will stick to the floor ever again.
Thanks for any help.
Dave
Dave K is offline   Reply With Quote
Old 08-29-2011, 05:48 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If you really want to put a stop to moisture migration you need to use the proper product. Drylock is not it. An epoxy product like Chapco Defender will go down in a single application and hold back quite a bit of moisture. It's meant for the kind of application you are talking about.
Darkling Designs
poppameth is offline   Reply With Quote
Old 08-29-2011, 08:52 PM   #3
The Chapco Defender looks great but a little out of my price range. The best thing I could find in my budget was MVR 8000 by Para Chem
http://shopping.netsuite.com/s.nl/c....t.A/id.3607/.f
Does anyone have experience with this product?
Dave
Old 08-30-2011, 05:50 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
What's your budget and where are you at? I've got a few kits of Defender left off a job I could get to you at a steep discount. I need to get rid of it before it expires anyway. I'll take a look at the other one for you when I get a chance.
Darkling Designs
Old 08-31-2011, 12:10 AM   #5
Thanks for the offer but at this point I am going to throw in the towel on the laminated flooring and just tint the slab and call it done.
Dave
Old 08-31-2011, 05:47 AM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Nothing wrong with that. Stained concrete is popular right now. I'd be hesitant on laminate anyway with that much variation in subfloor. You probably don't have a completely level surface to start with.
Darkling Designs
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 10:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
