Dry Wall First Or Tile First? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-24-2008, 05:03 PM   #1
Rewards Points: 342
Question
Dry wall first or tile first?
Doing a full bathroom renovation. Should I put the dry wall first or tile first?
tripower is offline   Reply With Quote
Old 06-24-2008, 05:41 PM   #2
Registered User
Termite's Avatar
I don't see any other way to do it than to install the drywall first, then tile. Otherwise you'll never be able to hide the transition between the backerboard and the drywall. You always finish your walls before tile.
Old 06-24-2008, 10:57 PM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
Drywall is installed before tile. I'd suggest using DensArmor wall board. It's paperless and therefore, mold resistant. Don't even think about greenboard. It was useless and obsolete the day it was introduced.
If you're tiling in a wet location, make sure you waterproof before you tile. Cement backer board is NOT waterproofing.
Good luck
Angus
My Albums
angus242 is offline   Reply With Quote
Old 02-21-2009, 02:54 PM   #4
Rewards Points: 342
Question
Just to resurrect this thread, if I am installing drywall on a concrete floor (before the tile) do I let the drywall sit on the floor or raise it just a hair off of the floor.
Old 02-21-2009, 04:18 PM   #5
Rewards Points: 342
Question
Good luck
How do you waterproof?
Old 02-21-2009, 05:39 PM   #6
angus242's Avatar
Yes, leave a gap. If you start from the ceiling you should end up with a natural gap between wall/floor anyway.
Angus
My Albums
Old 02-21-2009, 05:45 PM   #7
angus242's Avatar
With the use of a membrane. There are 2 main types; paint on or fleece sheet. RedGard is a paint on membrane. Kerdi is a fleece membrane sheet. They install differently but serve the same purpose. Either method will keep moisture from penetrating into the tile substrate which, if happened, causes many bad things (mold, rot, etc).
It is not necessary to use a membrane in a non-wet location like bathroom walls, just in a shower or tub surround.
Angus
My Albums
Old 02-21-2009, 08:38 PM   #8
Rewards Points: 342
Exclamation
And so I am assuming that when I begin tiling I tile under that 1/2" gap?
Old 02-21-2009, 08:40 PM   #9
Rewards Points: 342
And if I am building my own shower surround with tile how might I do that? I know in my older house it was build with sand and then a thin layer of concrete then the tile. Isn't there a better way to do this?
Old 02-21-2009, 09:36 PM   #10
Schluter makes a pan system that is presloped. They also sell curbs to go with it, or if you want you can frame up short walls.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 03-02-2009, 06:50 PM   #11
Rewards Points: 342
I am assuming that when using the cement backing board for the shower that I leave the 1/2" gap between the board and the cement floor just as I did with my drywall so that I can tile under it, correct? Or do I need more of a gap?
Oh, and what is the waterproofing procedure for the shower area before tiling?
Old 03-02-2009, 08:06 PM   #12
Proper installation calls for a pan and not using the concrete as the pan. Excess moisture will transfer through the concrete to other areas.
Old 03-29-2009, 10:29 AM   #13
Rewards Points: 342
Question
Can someone explain to me why a shower pan would cost $700!? Also, is there a link somewhere on DIY that gives a step by step as far as laying down the pan, liner, waterproofing, etc?
Old 03-29-2009, 11:15 AM   #14
That's cheap.
http://www.schluter.com/143.aspx
http://www.ontariotile.com/preslope.html
There are other products and variations of both methods that make it easier to do as well.
http://www.oatey.com/apps/catalog/in...an%20Liner.pdf
R&D Tile is offline   Reply With Quote
Tiling Shower: Decorative tile thicker than Wall tile digexpressions Remodeling 11 06-08-2008 05:49 PM
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-19-2008 10:26 PM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 03:16 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 12:01 AM
