Drilling For Tapcons - Flooring - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 09:26 PM   #1
Post
Drilling for tapcons
I haven't found anyone else having this problem. When pre-drilling for tapcons the bit (carbide tip) is worn out after about six holes. Is this normal? Any bits better than others? This could get expensive in bits alone!
ladanr is offline   Reply With Quote
Old 02-09-2010, 09:32 PM   #2
jlhaslip's Avatar
Rewards Points: 948
Is it older concrete? Using a hammer drill?
Slow the rotation speed down might help.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 02-09-2010, 10:59 PM   #3
Is the bit getting so hot that it turns blue?
You could be burning it out.
Try giving it the old in/out in/out.
A couple seconds of pressure, then back off.
And yes, the expensive bits last longer.
Dairylander is offline   Reply With Quote
Old 02-10-2010, 10:51 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Tapcons have their own drill bits. Is this bit you are using one that comes with the screws?
XXX
Old 02-10-2010, 01:17 PM   #5
remodeling pro
Sounds like you are turning the bits too fast. You should be using a rotary hammer, not a hammer drill or regular drill, they turn too fast and will just keep frying the carbide in anything tougher than cinder block.
As this is in the flooring section, are you putting down sleepers or subfloor for wood floor application. It is much quicker to attach using deformed shank drive pins, available at supply houses, than Tapcons.
troubleseeker is offline   Reply With Quote
Old 02-10-2010, 01:31 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Recently I was involved in the "firring-out" of poured concrete basement walls at my son-in-laws house. We purchased Tapcons by the box and each box contained a single drill bit suitable for the diameter of that particular screw.
We were getting about 100 holes in the concrete (per drill bit) using a rotary hammer and were quite happy with that.
XXX
Old 02-10-2010, 01:42 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
It would help if we knew what they are doing.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-10-2010, 01:49 PM   #8
How do you guys feel about powder-actuated fasteners for framing on a basement floor?
I agree that the split drive anchors are much stronger, but after a few jobs that had change orders to the layout, I was glad to actually be able to pull up the powder actuated nails.
And come on, they're sooooo easy.
Granite countertop drilling options dantm General DIY Discussions 1 02-09-2010 01:42 PM
Drilling Holes Through Foundation quickquestion Building & Construction 3 01-10-2010 01:42 AM
Sand(topping) Drilling Tips Requested Drawquarter Building & Construction 2 10-15-2009 07:42 AM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 04:07 PM
Lubricant for drilling in metal downunder General DIY Discussions 8 07-07-2008 07:52 AM
