Drill Into Concrete Slab? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 01:30 PM   #1
Post
Drill into concrete slab?
Hello everybody,
I have recently installed a floating laminate floor over a concrete slab. I need to put in a transition between the laminate and tile flooring, so I purchased a product that requires drilling into the subfloor during installation. I'm not sure this is a great idea because I'm afraid that moisture will come through the holes. Is this a problem? Are there any alternatives to this product? Thanks!
Mike
snowdenkays is offline   Reply With Quote
Old 08-23-2008, 02:15 PM   #2
ICF Construction
Use a glue or epoxy and put something heavy on it till it cures
Chris
Chris Johnson is offline   Reply With Quote
Old 08-23-2008, 03:10 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No more moisture will come through the holes than will rise through the concrete anyway. Is moisture an issue.
Old 08-23-2008, 04:48 PM   #4
I've never seen such a thing happen. For transitions to tile, I just use a nice aluminum edging that gets glued down with the tile.
I'd look at using epoxy as an alternative.
KHouse75 is offline   Reply With Quote
Old 08-23-2008, 05:12 PM   #5
Moisture hasn't been an issue so far, so I don't think it's lurking just out of sight. The transition piece I bought is aluminum with a concave channel underneath, and would take very well to epoxy. Thanks for all the helpful comments!
Old 02-21-2011, 01:29 PM   #6
How about liquid nails?
Will liquid nails hold the transition strip (t-molding) between concrete slab for a tile to laminate transition?
tadpole is offline   Reply With Quote
Old 02-21-2011, 04:09 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Liquid nails doesn't hold very well. Use PL400.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
