Dricore Question - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2014, 01:57 PM   #1
Rewards Points: 45
Dricore question
Guys, I'm planning on laying down dricore panels in my basement, I have a few questions. I have two steel support columns that I plan on boxing out with stone vener lowers and trim molding for the uppers, do I frame these columns in first and anchor them to the concrete floor and then cut the dricore to fit around or do I install all the dricore first and then frame these in and have them sit atop the dricore?
I will also be doing the same stone veners on the end of a bar which will require me to make a pony wall, again I have the same question will it be better to anchor the 2x6 I plan on using for a bottom plate to the concrete with tapcons, frame the pony wall, and then cut the dricore to fit around or place the wall atop the dricore?
I am thinking the wall and the base would be much more stable and move less is attached to the concrete. Attached is a pic of my basement project with the two columns I speak of. Thanks in advance for any help
Mike
Mlorek is offline   Reply With Quote
Old 02-21-2014, 02:09 PM   #2
bbo
Dricore question
I'd frame the items to the floor. and "float" the dricore around it.
it would be much more of a pain to affix to the dricore since you would need to secure the dricore the floor if you affixed the wall and column cladding to the dricore.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Mlorek (02-21-2014)
Old 03-15-2014, 04:38 AM   #3
James-Colls's Avatar
Dricore question
It would be much more of a discomfort to adhere to the dricore since you would need to protected the dricore the ground if you fitted the walls and line cladding to the dricore.
James-Colls is offline   Reply With Quote
To dricore or not to dricore..that is the question Gloria02 Flooring 15 09-29-2013 08:17 PM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 06:02 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
