Double Wide Mobile Home Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 05:31 PM   #1
double wide mobile home floor
I have a double wide mobile home. I want to remove the carpet and put down ceramic tile in living room. My problem is, this is where the two sections go together. Any advice would be greatly appreciated. Thanks
kubeanna is offline   Reply With Quote
Old 03-30-2009, 07:04 AM   #2
ccarlisle's Avatar
Well, what can I tell ya...first it's not the ideal subfloor for ceramic or any other tile (eg porcelain or stone) that can crack with any movement from above or below. I mean if it 'cracks', it's not a danger, just unpleasant to live with and defeats the purpose of tiling in the first place, IMO.
But the cracking will depend on many more structural issues that tiling a kitchen in a house...movement up or down of one unit relative to the other, horizontal or vertical, and if there's a solid structure there to begin with, not - say - tires...it would be a challenge...
Because even if one of the units has a solid floor and you tile on top of that, you could put an expansion joint between the 2 units that could 'flex' with the movement of each unit - but that might look funny.
You could put in a subfloor that spans the two units - but that will flex too. I am also concerned that trailors aren't meant for the added stress of tiling.
I'd look at man-made tiles, as are mentioned in other threads.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-30-2009, 04:00 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Since your subfloor is probably beaverbarf or worse, I wouldn't recommend tile. Maybe you could try some of the laminate that looks like tile.
Old 03-30-2009, 05:45 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You could use DuraCeramic if you get past that stigma.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Mobile Home Furnace problem jbenn003 HVAC 1 12-01-2008 05:08 PM
deck for a mobile home rln17 Building & Construction 2 09-09-2008 04:51 PM
