Old 03-05-2008, 09:03 AM   #1
Question
Door jam between rooms is drywall
I know that I have to saw the bottom of my wood door jams to slide the laminate under but, the wall between living room(where the laminate is going) and the dining room is just finished drywall (with metal corner bead) with no wooden door jam. Since the floors in the two rooms are not going to be the same height, I have a reducer trim and I can't just run the baseboard around the corner. Can I use my 'wood saw' to cut under the wall with the metal corner bead?
dsanders55 is offline   Reply With Quote
Old 03-05-2008, 09:33 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
With such an installation, I'd suggest that you DO NOT touch the drywall. It will not react to cutting the way a wood jamb will. You would most likely end up pulling on the corner, and causing cracks above it. Additionally, if you attempted to do such a thing, you will end up with a very ugly mess down there. This is drywall and not wood.
I say again: DO NOT attempt to cut the drywall corner in any way.
Leave the drywall corner where it is.
Consider one of 2 options:
1.) Install a threshold, transition or diffusor strip over the opening area, that will allow the laminate to continue to float.
2.) Install shoe-base (base-shoe), over the edges of lower drywall jambs to cover the expansion gaps of the laminate. You may be able to install it returnign the ends, or tastefully "meld" it into any adjacent trim (base).
- Build Well -
Old 03-05-2008, 06:35 PM   #3
Sound advice!
mike costello is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Replacing drywall in shed with osb elcarlstono Building & Construction 1 12-27-2007 07:51 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
