Dogs And Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-15-2013, 02:48 PM   #1
dogs and flooring
What is the best material to use when you have dogs? Tile or wood? Or something else. We are redoing a large (22x24) living room where we spend most of the time. It would butt up to dark parkay flooring
sylvia43551 is offline   Reply With Quote
Old 08-15-2013, 02:56 PM   #2
Rewards Points: 274
Tile is the best in this case.
alexjoe is offline   Reply With Quote
Old 08-15-2013, 03:08 PM   #3
Thank you!
Old 08-15-2013, 03:40 PM   #4
Too Short? Cut it Again!
There is another thread running on just this topic in the flooring section. You might scan it for options. Strand bamboo and paying close attention to the quality of the actual finish on the material came up. I think you should be able to click on this link to get there.
hardwood for dogs
This topic comes up often so in case we all missed something, you might use the search engine to explore other similar threads.
Old 08-20-2013, 10:10 PM   #5
From experience the best material for dogs is either tile or laminate if you want the wood look. Laminate is extremely durable.
Godspede619 is offline   Reply With Quote
Old 08-21-2013, 12:11 PM   #6
Laminate is not durable and would be a horrible choice. I would never use laminate on a project for anything! It is cheap but it looks it and the inexpensive stuff does not last.
Most of it, especially what box stores sell, is a sandwich of protective film over a thin layer of patterned material (the combination of these two layers is often not even as thick or protective as two to three coats of poly would be) sealed to a cheap substrate like particle board. if the dogs scratch it up, there is no way to refinish it or to remove deep scratches. It is gone.
Perhaps you meant quality engineered flooring? Maybe but same issues as hardwood or bamboo.
Old 08-21-2013, 03:48 PM   #7
Rewards Points: 736
Glad someone shot down that laminate idea. God I hate that stuff.
TheBobmanNH is offline   Reply With Quote
Old 08-21-2013, 06:53 PM   #8
Rewards Points: 77
How about Armstrong Vinyl Plank...
http://www.armstrong.com/flooring/lu...oor-117511.asp
daveplot is offline   Reply With Quote
Old 08-21-2013, 08:32 PM   #9
Rewards Points: 960
Concrete is pretty durable, but you would have to seal it with something.
Terrazzo looks nice.
How about tile?
cleveman is offline   Reply With Quote
Old 08-21-2013, 08:40 PM   #10
Was going to post another similar thread and then realized I already did. Sorry.
What is the best flooring to get if you have dogs? DMW004 Flooring 18 10-12-2012 01:04 AM
Allure flooring and big dogs EFTHIM Flooring 1 05-31-2012 01:23 PM
Wife wants bamboo flooring. Two dogs pee on floor. Sowak Flooring 44 03-05-2012 05:25 AM
White dogs and wood flooring Karri Flooring 9 05-26-2009 10:54 AM
Will Laminate Flooring Hold Up With Dogs In The House? FEDERAL GOON Flooring 3 06-18-2008 01:39 PM
