Does Cement Board Require Thinset To The Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-19-2008, 10:32 PM   #1
Stretch
Does cement board require thinset to the underlayment?
Just finished installing a new subfloor & underlayment (3/4" and 1/2" plywood), old one was shot...looks great now, solid as a rock. Glued & screwed the subfloor...screwed the underlayment (UL) to the subfloor while avoiding the joists. Ready to start my first tile project. Need to lay the CBU in preparation. My question is: Do I need to set the CBU to the UL with thinset?
All the applications I have seen do this. My concern is...if I screw up, or sometime down the road, I need to pull it up...can I simply nail the CBU down w/o the thinset? Without the thinset, I can (relatively) easily remove the tile / CBU from the underlayment, if needed. I will nail (not screw) down the CBU to ensure relatively easy removal, if needed.
I approach each project with a devils advocate mindset...if I mess up, how can I recover with minimal pain & expense. With the CBU "glued" to the UL, it would be very painful to recover w/o removing the UL / subfloor.
Bring it on...and thanks in advance!
scheenstra is offline   Reply With Quote
Old 11-20-2008, 09:16 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
YES, absolutely. ALL cement board manufacturers require it. The TCNA requires it. The NTCA requires it.
Well there ya go!!!
Yow-well....GOOD LUCK with that theory.
Don't use thinset under the cement board and see how long it takes the devil to come knocking at your door.
If you play by the rules and use unmodified thinset (as you should) you won't be "glueing" the cement board to the substrate to begin with.
The thinset is there to fill voids and firm the cement board, it's not there to glue it to the floor.
Old 11-20-2008, 11:22 AM   #3
Floorwizard's Avatar
Let's put it this way....
Bud is right...
However we put Ceramic tile over ROOFING FELT in our showroom which is on uneven concrete. That is so we can remove with very little effort to change out. This is not a recommended practice for homeowners. But all is doing very well.
Bud's point is that even though you MAY be o.k. installing outside of the box, chances are you will not be o.k. and it will cost you.
We are pro's here, so most of the time if you want exact pro answers, you will get it.
I would never install tile over felt in a home, but then again, it's supposed to be permanent right?
Maybe Vinyl is a better answer for you if you are looking at temp options.
Floorwizard is offline   Reply With Quote
Old 11-20-2008, 07:59 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
However we put Ceramic tile over ROOFING FELT...
For temporary installations that's the way it is done. Trade shows, showrooms, exhibits, displays, seminars. Then the tile is ripped up and thrown away. This is no place for that kind of information I don't think.
Three months from now someone will be here complaining that thier tile floor they installed over roofing felt failed and Florcraft said they could do it.
Old 11-20-2008, 08:23 PM   #5
This is a place for ALL info!
That would be sad because I said...
and.....
so I think I covered myself.
But I am not a lawyer.....
Just in case you are right though let me say this...
You will go to your mailbox and send Florcraft $1.00
Do it....
do it now.....
Old 11-20-2008, 10:43 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
PM me your mailing address...I have something for you anyway.
Old 11-21-2008, 11:11 AM   #7
Are you wearing a hooded sweatshirt and big dark glasses?
Do you live in a shed in the woods?
Now I am worried
Old 11-21-2008, 12:47 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Whatever.......it's your loss! I was going to send you a gift from corn-country but that's OK, others will appreciate it.
I do have relation in Anchorage just a hop skip and a jump from you.
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 06:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
