#1 |
Brand Newb
do I need a vapor barrier?
I have vinyl peel and stick tile over a slab. Do I need to lay down a vapor barrier before I put down laminate flooring? The laminate already has a foam backing on it.
#2 | |
Lic. Builder/GC/Remodeler
do I need a vapor barrier?Quote:
Vinyl peel and stick will not make up an appropriate vapor barrier, as it does not serve a means of a 'continuous' separation type material between the concrete surface and a laminate floor product. I would advise you to install a poly type vapor barrier. Tape any seams that arise during the installation process. By the description that you have given of the flooring material you want to use, I would guess that it might be a 'Dupont' brand flooring. Whether it is or isn't you can can also review more information at this link: http://www.diychatroom.com/newreply....wreply&p=38202 Note the instruction line on the link which states: 'If installing over concrete or a concerte floor covered by tile, you must lay down a 6 mil plastic sheet vapor barrier.....'
- Build Well - |
#3 |
Brand Newb
I have vapor barrier, but it is in 10'X10' sheets and it's giving me problems. I just decided to cut the sheets into smaller strips to make it easier to work with.
#4 |
but you will need to overlap to make a proper barrier..
#5 |
Brand Newb
do I need a vapor barrier? |
#6 |
HA!
Would have been a good idea
#7 |
Brand Newb
Just sent my son to stay with grandma and grandpa so I can work on the floor. It's moving right along now! I've got all the tricky nooks done. The nooks couldn't be on the right side of the room now could they?
#8 |
oh....of course not.....
| Display Modes | |
