12-16-2010, 11:18 PM
#1
Do I need to remove Floor Trim...
... For installation of allure Trafficmaster? I had carpet previously, so there is plenty of gap for the tile to slide under. Any downside to not removing?
Thanks for any help/Info.
12-18-2010, 05:51 PM
#2
Dumb Question?
12-18-2010, 06:07 PM
#3
the Musigician
There are no dumb questions, just dumb answers.
What is the gap distance now?
You may end up wanting to pull the baseboards anyways, to LOWER them down to the new flooring!
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
12-18-2010, 06:25 PM
#4
Pro Flooring Installer
It would probably easier to install the flooring with the trim off, than to try to slide the flooring under.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
12-18-2010, 07:05 PM
#5
Thanks Rusty! Doing it now.
Im new to this... so probably will have more dumb questions... but when I get to the door jambs.. undercut or Cut around?
Seems Undercutting is the best option, but I dont have the proper saw for it.
12-18-2010, 09:15 PM
#6
You can undercut with almost any kind of handsaw. Just lay a scrap on the floor and lay the saw flat on top to undercut. Under cut looks a lot better since if you butt up to it, you have to leave a gap. You can fill a gap with caulk if necessary.
12-18-2010, 10:37 PM
#7
Okay, makes sense.
One more in regards to the baseboards... someone suggested that if I dont remove the baseboards, I can just install tile just up to them (leaving a gap), and install quarter round on the bottom of the base board (covering the gap between vinyl and baseboard)
Any downside to that method?
Thanks for all the help so far!
12-18-2010, 10:56 PM
#8
That will work fine as long as you fasten the 1/4 round to the base and not the floor.
12-19-2010, 12:22 AM
#9
A Little Of Everything
Originally Posted by dbower
Okay, makes sense.
Rusty has you covered, Bud!
Personally, I like the look of having the quarter round/toe kick on the base moulding. Seems more finished. Also, when removing old base moulding, it's easy to damage the wall.
Just make sure, like Rusty said, that you nail it to the moulding and NOT the flooring.
12-19-2010, 01:17 AM
#10
Awesome! Thanks guys!!
12-20-2010, 12:55 PM
#11
The documentation for the flooring mentions ordering 'hidden transitions strips'. Think I'll need some of these for transitioning from the hallway to the Bedroom.
Website has no way to order, no one answers at the number for the accessories dept. Is there any other way to buy these, or can someone suggest an alternative?
12-20-2010, 01:54 PM
#12
Go to your local Home Depot or call them. They sell this product and should have the transitions.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
