Old 12-06-2010, 01:04 AM   #1
Do I need a professional to do Asphalt Topping?
I just got a 4,500 square feet driveway and parking lot resurfaced with new asphalt. The contractor now is advising me to get the asphalt seal coated with some type of topping.
Here's my question......Do I really need to seal coat it? Next question is do I need to hire a professional to do it, or can I do it myself?
stanlam is offline   Reply With Quote
Old 12-06-2010, 08:34 AM   #2
See: http://www.asphaltinstitute.org/publ..._FAQs.asp#seal
Excerpt:
Q. Should a newly paved driveway or parking lot be sealed (or seal-coated)?
A. No. A well-designed and constructed low traffic volume pavement, such as a driveway or parking lot, should not require sealing for approximately 2 to 5 years – depending on severity of climate and quality of original work. If a new pavement is porous, meaning it allows water into the pavement rather than shedding, or draining off, the rain, this pavement might benefit from a light application of a low viscosity asphalt emulsion. See Application Instructions below.
Q. When should a driveway or parking lot be sealed?
A. Sealing is effective to renew old asphalt surfaces that have become dry and brittle with age, to seal small surface cracks and surface voids, and to inhibit raveling (loss of surface aggregate). So, sealing should be done as soon as any of these distresses are noted.
bob22 is offline   Reply With Quote
Old 12-06-2010, 11:58 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Wrong forum,
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 12-06-2010, 08:54 PM   #4
I guess a parking lot is sort of like a floor?
Old 12-06-2010, 09:01 PM   #5
I'm surprised it's been on here all day and no one has moved it.
Need advice on 1 1/2 inch of asphalt overlay on concrete and old Asphalt stanlam Off Topic 9 12-05-2010 08:46 PM
Need advice on 1 1/2 inch of asphalt overlay on concret and old Asphalt stanlam Landscaping & Lawn Care 1 11-28-2010 05:50 PM
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 03:30 AM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 10:10 PM
Asphalt Question javan General Discussion 5 07-16-2008 07:38 AM
