Do I Need Ditra/uncoupling Membrane? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 07:19 PM   #1
Do I need Ditra/uncoupling membrane?
After working my ass off finishing the basement over the last 8 months or so, I'm finally ready to get the tile down in the bathroom and install the toilet and vanity so I don't have to go upstairs to use the facilities
The entire basement has Barricade subfloor tiles and aside from the bathroom, laminate everywhere. I want to lay some tile down in the bathroom this weekend as there isn't much that needs to be done and I might have some time. My question is do I need to use an uncoupling membrane even though the Barricade subfloor tiles sit directly on the concrete slab? Ditra sold at the big box stores isn't cheap and I haven't really looked at a local shop for an alternative but I figured I'd ask here to see if I even need the stuff to begin with.
Thanks!
hpsguy is offline   Reply With Quote
Old 09-05-2013, 08:52 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 310
Hi guy,
Maybe it's me, but looks like the manufacturer is going out of their way to not show detailed instructions on what types of flooring can be installed over Barricade.
I don't think ceramic tiles is on the agenda. I know Ditra would require sheets of plywood or OSB first, but since Barricade is floating, I think it's a no go.
Please link us to the data that specifies how to safely install ceramic to this product.
I saw Barricade installed in a client's basement a few months ago. Laminate for most of the floor except he was planning to install a vinyl tile for the bathroom floor. He mistakenly glued some 5.5 mm luaun to the Barricade thinking it would be a good base for the vinyl tiles. WRONG. I walked in the room and noticed the ply was buckled and needed to be removed, time for plan B.
Jaz
Old 09-05-2013, 09:11 PM   #3
Well I know DriCore recommends to not use Ditra with their product, which is a very similar subfloor product. The actual area being done is maybe 40sq feet.
Old 09-05-2013, 09:26 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 310
Well....right.
Ceramic tiles in this type of installation goes direct to the slab or over Ditra or similar product. You'll have a drop of course.
Jaz
Leaks in membrane roof at posts and edge leakhelp Roofing/Siding 13 09-09-2012 08:22 PM
Shallow pitched roof membrane? SteveB87 Roofing/Siding 6 07-26-2011 10:16 AM
Keraflor for Kerdi membrane myfirstbathroom Tiling, ceramics, marble 9 04-20-2011 02:21 PM
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 03:18 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 06:16 PM
