Do I Fill The Cracks When I Am Putting Peel And Stick Tiles? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 03:12 PM   #1
Do I fill the cracks when I am putting peel and stick tiles?
I have a plywood sub floor and am going to put peel and stick tiles down. Do I need to fill the cracks and if so with what? The manufacturer instructions say that I do not have to put anything on the plywood but I have added a glue in the past and have had great success with peel and stick tiles.
bherdman is offline   Reply With Quote
Old 04-05-2010, 03:23 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome.
Thread moved to get speedier response.
If you mean the gaps in the T&G subfloor, you could use caulk to fill the cracks, but wait until completely dry before laying the peel n' stick tiles. (overnight would be best) DO NOT use silicone caulk of any kind.
The only reason to do this is to avoid tile sagging into the crack over time, but it would be barely noticeable in most cases.
Be sure floor is VACUUMED clean before application as well.
*good luck*
DM
Old 04-05-2010, 03:26 PM   #3
the Musigician
I should add that the tiles will not stick to silicone.
Other compounds may be better to use as well. Guys? Spackle? Bondo? LOL
DM
Old 04-05-2010, 03:47 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 54
Cementious based floor fill.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-05-2010, 04:47 PM   #5
Rewards Points: 266
A question that has been bugging me about peel and stick tile. A HD rep reccomended a primer designe specifically to go down on the subfloor prior th sticking down the tile. Is primer worth while. The 1/4 inch plywood I pland to use is quite absorbant. It seems like they would stick very well to it already.
Jim F is offline   Reply With Quote
Old 04-05-2010, 05:01 PM   #6
Preping your plywood sub floor is good pratice of the flooring trades for vinyl tiles glue down or peal'n stick and sheetgoods.
Durhams RockHard (water putty) was an old favorite of mine for seams and set nails or screws. Apply with 4" or wider knife if needed... let set..scrape ridges and sand smooth. Also good for chips or other flaws on the plywood. Get all the dust and debris up before you start to lay the flooring.
May be better products out there now...
Big Bob is offline   Reply With Quote
Should I fill the gaps? TReally Flooring 1 03-09-2010 08:06 AM
Re-Roofing: Okay to Re-Use Peel n Stick? GrillMouster Roofing/Siding 8 12-06-2009 02:55 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
Peel & Stick Tiles onto Plywood Subfloor kimmyb Flooring 5 01-25-2009 04:07 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 08:52 AM
