Closed Thread
Old 08-03-2009, 07:08 PM   #1
Ditra and Suntouch warming system?
Hi, I'm wondering if anyone has installed floor tile using Suntouch floor warming system with Ditra? I'd like to have heated tiles in my bathroom and plan on using Ditra, but wasn't sure if the heating system can be used in conjunction with it? The heating system is in the form of heating wires wound through a mesh mat that is set in mortar under the tile.
Thanks.
Hrblmom is offline
Old 08-04-2009, 06:52 AM   #2
Doer of Many Things
poppameth's Avatar
Yes it can be used. We installed the heat as recommended by the heat manufacturer, using a self leveling compound to embed the coil. Then you thinset your Ditra on top of the poured compound per Schluter's instructions. The exact order of installation is detailed in the Ditra installation handbook, downloadable from Schluter's website.
poppameth is offline
Old 08-04-2009, 11:26 AM   #3
Thanks. The directions for installing the heating mat say to adhere mat to backerboard using adhesive provided and use thinset over to adhere tile. Is it best to do this under Ditra or can it be done over so the heat is closer to tile? Did you use the same system? This is Watts SunTouch Floor Warming System.
Hrblmom is offline
Old 08-04-2009, 07:10 PM   #4
Doer of Many Things
poppameth's Avatar
We haven't used that exact system. We've used Warm Tiles and Nuheat for the most part. They should all be similar though. If it says to adhere it, then use the adhesive. As far as thinsetting, I would check with them to see if you can use a self leveler with their system. SLC is a lot easier than troweling thinset onto the mat and less chance of damaging the mat. It'll also fill it in better and give you a better surface for Ditra. With thinset I'd say fill it in, let it cure, and then use more thinset to attache the Ditra. It's more work that way.
Old 11-14-2009, 01:36 PM   #5
Extreme DIY Homeowner
Scuba_Dave's Avatar
Originally Posted by 26yrsinflooring View Post
Funny, when I do that they call it advertsing and remove the post
Did you report the post as Advertising?
The answer would be NO
Advertising posts ARE removed when reported
It's not possible for us to read every single post on this forum
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Scuba_Dave is online now
Closed Thread
More On This Topic
Hi, I’m Faith and I’m with Flat Fork Studio, and I’m here to discuss the different kinds of adhesives that you might want to use in doing your tile mosaic project. There’s several different applications. You first need to decide... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m here to show you some basic tools that you want to have on hand when preparing to do your mosaic tile project. First we have a caulk gun, Liquid Nails adhesive. This is one type of... Read More »
Latex-based adhesives are mostly used to glue carpets and other flexible objects. Thanks to its flexibility, the adhesive is particularly helpful for these uses, although the bond is not a particularly strong or durable one. Latex-based adhesives do not... Read More »
So we're talking about Pilates warm up, and the first thing that we need to look at is neutral spine. This is a fundamental concept, that's all over the Pilates repartee. And what it is, is when all three curves of your spine are present; the lumbar... Read More »
Hi, I’m Faith, I’m here at Flat Fork Studio and I’m going to show you how to glue your mosaic pieces down to your final piece. And at this point I would use a thinset- a premixed thinset- and it comes from the hardware store already... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
