Ditra With Partial Heat - Flooring - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 11:39 PM   #1
Ditra with partial heat
Hello,
I have searched but didn't find the answer to my question. I will be tiling our dining area and kitchen but only plan on putting radiant heat in the kitchen. How do I compensate for the added height of the wire/mat heating in the kitchen? I plan on using Ditra. The subfloor is plywood and the tiles are 16x16 porcelain. Thank you.
Deadeye is offline   Reply With Quote
Old 02-08-2012, 08:15 AM   #2
Civil Engineer
Rewards Points: 4,526
There is very little extra height due to the wires, they are typically about 1/8 inch or so, and they are covered in thinset or SLC anyway.
Daniel Holzman is online now   Reply With Quote
Old 02-08-2012, 09:02 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 244
Well...yea, that's the answer. The entire floor gets covered with self leveling cement to make the floor flat. Although the wires are about 1/8", that is way too thick to just go over them. What do the directions tell you to do?
Jaz
JazMan is online now   Reply With Quote
Old 02-09-2012, 11:36 AM   #4
Sorry, didn't give enough information. Will use SLC in kitchen that is about 150sq ft but didn't plan on using SLC in the 250sq ft dining area. This is because it seems to be flat enough and I didn't want to spend money if not needed.
I talked to Schluter and they recommended putting unmodified thin set on the SLC (under the Ditra) and modified on the plywood in the dining area. To make up for the "lower" area that doesn't have SLC, they recommended increasing the amount of unmodified thin set between the tile and Ditra.
Old 02-09-2012, 03:11 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 244
Well yes, you have to use the "substrate-appropriate" thin set regardless.
WOW, they actually said that? I hope that is not exactly what they meant.
How do you build up an extra 1/8 - 3/16" with thin set? I don't know what they said or what the person meant, but that advice is definitely wrong.
Jaz
Old 02-09-2012, 08:46 PM   #6
Thanks Jaz. That is what I was told but I am going to take your advice and pick up more SLC tomorrow so I can cover the whole tiled area.
Old 02-09-2012, 09:28 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 244
Maybe he/she meant to apply a little more thin set on the backs of the tiles just in the transition area? Make a slight ramp? In any case that is a tile installation technique and is out of their expertise.
It's best to start with a flat floor. Have you ever used SLC? Don't forget the primer.
Jaz
Old 02-09-2012, 09:54 PM   #8
I have very little experience with SLC but do know I will need to prime first.
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
which comes first..ditra or floor heat? big guy1 Flooring 7 03-30-2010 09:29 AM
Aux heat doesn't come on during defrost cycle hesse HVAC 5 03-18-2010 05:10 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
