Ditra Over Basement Slab? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 11:54 AM   #1
Ditra over basement slab?
Hi all:
I know this topic has probably been discussed here on the boards before but I wanted to run my plan by someone before I move ahead. I've decided to tile my basement slab. Sounds to me like installing ditra as an underpayment would be the best option. However, the basement does get some moisture, particularly at the edge of the room that faces the backyard. My question is this: if there is a little bit of moisture that comes in, would I run the risk of trapping some of that moister under the Ditra? Would I be better served by skipping the Ditra and tiling directly over the slab? Thanks in advance!
Trustmemalawyer is offline   Reply With Quote
Old 08-12-2011, 05:58 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes.
Yes.
XXX
2X4 Framing on sloped basement slab chobio Building & Construction 2 07-02-2011 08:11 AM
retrofit slab insulation in finished basement... worth the trouble? gbwillner Building & Construction 20 11-17-2010 12:05 AM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
bathroom basement subfloor on concrete slab Gus72 Building & Construction 9 01-19-2008 05:57 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 12:52 PM
