To Ditra Or Not? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-13-2008, 07:49 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 288
OK, good move obviously. Use 3/4" subfloor exposure one or similar. Depending on the brand, you should check with their specific guidelines for installation. I imagine you'll be installing 2 layers? The second being an underlayment. Make this sheet at least 3/8" but thicker is better, so go ad thick as possible. Then Ditra over that.
Jaz
Old 02-14-2008, 06:14 PM   #17
Thanks again for the great information. I read the article "Position of underlayment to prevent cracked tile and grout" so I will use two layers of 3/4" plywood. Taking up the floor is hard. It has the old square nails. I have already destroyed two carbide saw blades but the battle goes on.
JamesEric is offline   Reply With Quote
Old 02-23-2008, 06:41 AM   #18
I have completed the installation of the subfloor and underlayment. It is like night and day. I used Avantech subflooring and 5/8" plywood underlayment. Now my floor has a very solid feel. I have total confidence in this substrate. My only concern is a 1/4" low spot in the center of the floor. Should I patch it before the Ditra or just use the thinset when I lay the tiles?
Old 02-23-2008, 04:15 PM   #19
I do believe a layer of thin set should be put down then the ditra, can you level the area with thin set before you lay down the ditra?
mgarfield is offline   Reply With Quote
Old 02-24-2008, 09:01 AM   #20
Tile Contractor
Bill_Vincent's Avatar
Either before or after, but if you do it before, I'd do it with a thinset that's highly modified-- something like Laticrete's 317 mixed with their 333 additive, or Mapei's kerabond mixed with thier Keralastic-- something that's going to grab that wood and not let go.
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Old 02-24-2008, 11:42 AM   #21
Thanks. I did it after as I set the stone.
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Installing Ceramic tile: Ditra over Vinyl or rip out and use 5/8 Plywood? ppieda Flooring 2 10-05-2007 12:01 PM
have osb subfloors that squeak on 3 story duplex runbikeengr Flooring 12 04-19-2007 02:33 AM
Tile a shower base? always something Flooring 6 03-19-2007 10:58 AM
Ceramic Tiling on a Slab nsb318 Flooring 3 03-01-2007 03:23 AM
