Ditra On Covered Balcony - Flooring - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 02:36 AM   #1
Ditra on covered Balcony
My first post, and tile project. Planning to use ditra on a 175 sq ft. covered 2nd story balcony. Substrate is a like an epoxy or elasotmeric over plywood. Wondering about what morter to use under the ditra. Also there is one area on the deck that has a small hump, may 1/4 in height where the surface is not perfectly flat. You cant see it, but i checked with a long straight edge. Friend recommended using Flex Bond, but it takes a long time to set. I thought about using hardiboard under the ditra to smooth out the area, but that would mean. Not concerned about the cost, but adding the hardiboard raises the height of the porceline tiles a bit higher than i think i have room for. Ive enjoyed reading other posts and decided to throw this post out and pray for some sound advice.
Also, this forum seems to acknowldege using Ditra. But I have talked to several building suppliers that have never heard of Ditra. Wondering why that is.
Siegelpmp is offline   Reply With Quote
Old 09-11-2011, 07:58 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 412
You should start with a good flat structurally sound subfloor and joists system. The balcony should have the proper pitch for run off. How it's built depends on many factors that we'll get to with a few more Q&A's.
One thing for sure, you can not use Hardie backer outdoors. Anyway, how would a concrete backer or plywood take that hump away? It's not possible.
You've been talking to the wrong people. That's a good question to ask them to answer why not.
Jaz
Old 09-11-2011, 08:06 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 412
system error - post duplicated
Last edited by JazMan; 09-11-2011 at 08:19 PM. Reason: system loading error - duplicate post
Tags
ditra , flex bond , hardibacker , thinset
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
confusion over thinsets for installing Ditra over heated flooring fhknox Flooring 12 01-19-2009 06:21 PM
2nd Story Covered Balcony hammermonkey Building & Construction 4 10-13-2008 06:57 PM
Ditra vs. Ditra XL richbl Flooring 3 10-13-2008 09:07 AM
