Discoloring Vinyl Floor - What Causes? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 08:20 AM   #1
Smokin Joe
jombres's Avatar
Question
Discoloring Vinyl Floor - what causes?
Hi All
I have a vinyl kitchen floor which extends down the hallway, and into utility room. It was pretty new when I moved into the home 10 years ago, but in the last few years, has developed a few dark spots my wife described as scuff or magic marker spots. We noticed a large area of the floor darkened, and now, a whole area of the floor, has discolored and it looks almost as if mould was growing on it, but it is in the body of the vinyl itself.
It's almost like, we used an incompatible cleaning product with the flooring, and there was a chemical reaction which darkened the floor. Except, its highly localized to one specific area. It is conspicuous that the darkening area is by the sink and dishwasher, which suggests moisture.
I most likely will hire a flooring man to do the job, but would like to rectify the problem before I replace (or have replaced) the floor.
Here is a few photos, does anyone have any ideas? Thanks
joe
jombres is offline   Reply With Quote
Old 01-22-2008, 10:09 AM   #2
Home Remodeler
Rewards Points: 164
I would look for a water leak at the sink and dishwasher. Looks like water damage to me.
mikey48 is offline   Reply With Quote
Old 01-22-2008, 03:59 PM   #3
We did not have a water leak, but moisture rose up through our slab ( texas ) foundation and caused discoloration in the vinyl. It looked similar to your
pics but in more, smaller areas. We replaced our floor with a ceramic tile
floor and it's been fine... that was 5+ years ago. Haven't had any issues
with our tile floor.
jack
MrLinux is offline   Reply With Quote
Old 01-22-2008, 05:04 PM   #4
Rewards Points: 150
Thats moisture for sure. Is that a dishwasher in the pic? Im betting thats the culprit.
mike costello is offline   Reply With Quote
Old 01-22-2008, 07:02 PM   #5
Smokin Joe
jombres's Avatar
if it was a moisture problem, wouldnt the vinyl be "springy" or make...crackly or creaky noises when walked on? The floor is mechanically sound, sounds good, no bounce or noise or any of that.
Yes that is the dishwasher in the picture, the black appliance. And the sink is to the left of it. The house is on a crawlspace, I failed to mention.
Also, if moisture, wouldnt the dark spot go right up to the dishwasher (theres a band of white where the floor is not discolored) right in front of the dishwasher. Also, the floor is not coming up at the edge.
I think I might have to crawl under the house. (man I hate that) WIsh I had a basement.
joe
Old 01-22-2008, 07:55 PM   #6
I agree. That looks like water damage from below.
NateHanson is offline   Reply With Quote
Old 01-22-2008, 08:43 PM   #7
Rewards Points: 150
Water can surprise you . It wicks away on the easiest path it can find.
If it is a relatively new leak (less than a year) stuff has not reached the rotting phase yet.
Looks like the vinyl may be under the cabinets and dishwasher so you wouldnt see any peeling.
My money is still on the dishwasher
Old 01-22-2008, 09:45 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 232
It's water for sure! No need to go in the crawl space. Just crawl over and remove the kick panel of the dishwasher and or supply line from the sink and you will find wet.
Jaz
Old 01-23-2008, 12:33 PM   #9
Floorwizard's Avatar
Gotta be water.
I know of staining from floor mats and discoloration from incorrect adhesive. Nether look like that.
Water damage does though
Floorwizard is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
