Discoloration On Oak Flooring Question, And Is There UV Protection? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 07:07 AM   #1
Question
Discoloration on oak flooring question, and is there UV protection?
Hello
I just bought a house (last night, in fact), and the floor guy is showing up on Monday to refinish the floors. It's a dark home, so we chose no stain at all and just a 3-layer protective clear coat for wear and tear on our white oak. A very light finish in order to help brighten the rooms up a bit.
I'm worried that we will end up with uneven discoloration because of the placement of the furniture. the current floor has a BIG "clean" area where the previous owner's sofa was, and it's hideous. People tell me this is cause by UV through the window on oil-based finishes over years and years of time.
How can I prevent this, and should I go with oil-base or water-base for the finish? (We have 2yo and a 7yo, and will eventually have a puppy, if that helps answer wear & tear questions). Are there UV-protectant urethane finishes that I should request?
spdorsey is offline   Reply With Quote
Old 05-06-2011, 10:49 PM   #2
Question
Is this issue difficult to address?
Laminate Flooring Question cacell Flooring 7 03-30-2017 08:01 PM
new construction flooring question bgabrielse Building & Construction 5 12-05-2010 04:52 PM
Question about laminate flooring jwemt81 Flooring 8 05-11-2009 12:09 PM
Wet Flooring Replacement Question RetroActv Flooring 1 04-03-2006 04:57 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 12:05 PM
