Directions Of Hardwood Floor And Joint - Flooring - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 04:24 PM   #1
Post
directions of hardwood floor and joint
General speaking, hardwood floor should be installed perpendicular to joints. however i have dinning+living room (300 sqft) is 12'X24' with two bay window (two directions) that makes joints have two directions too.
I want to install hardwood floor parallel to joints at 75% area. The subfloor is 5/8" OSB, it looks strong. I will cover 7/16" OSB over the subfloor to make it stronger. I don't it is ok or not.
wjw1 is offline   Reply With Quote
Old 01-24-2010, 09:00 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
It's OK to run the planks with the joists if you install a sheet of underlayment. But I doubt 7/16 OSB is an underlayment, it's sheathing. I would install 1/2" plywood instead and don't buy the cheap CDX stuff. That's sheathing too. Get B/C ply.
Jaz
Old 01-25-2010, 08:06 PM   #3
what meathod are you using to install the wood?
just tile is offline   Reply With Quote
Old 01-25-2010, 10:38 PM   #4
wood is hardwood floor?
drill hole then hand-drive nail
Old 01-26-2010, 01:56 PM   #5
jazman is correct. your hard wood don't have a tongue and groove.
Old 01-26-2010, 10:38 PM   #6
the hardfloors are quite common: red oak 3/4" thick and 3.25 wide, canadian made (goodfellow), prefinished hardwood floor with tongue and groove. I already installed in family room. I want to install parallel with joints in living and dinning room, that looks good I think.
But it is not strong as perpendicular to the joints. That is why I want to add OSB (or T&G, or plywood to make subfloor strong enough)
thank you and jazman to answer my question
Old 01-27-2010, 05:01 PM   #7
your welcome, i am sure you will end up with a beautiful floor. send pic when you are done.
