Directional Hardwood Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 02:34 PM   #1
Directional hardwood flooring?
I am having a house built, and in our contract I added that the hard wood floor be run left to right in the hallway and in the dining room with a perpendicular threshold piece to separate the two areas. Now that the floors are in(not as written in the contract) the contractor is saying they cannot be run as is in the contract due to the type of flooring. It is just 2" tongue and groove planks on a concrete slab. Is there any reason the flooring could only be run front to back instead of left to right with a threshold at a doorway?
JAHTIRA is offline   Reply With Quote
Old 08-04-2011, 03:50 PM   #2
on a wood floor the hardwood should be run perpendicular to the floor joists. on a concrete floor i wouldnt think it would make any difference which way it runs. if its stated in the contract then you should have them change it.
Old 08-04-2011, 03:55 PM   #3
Experienced
Jackofall1's Avatar
Welcome JAHTIRA, to the best dary DIY'r site on the web.
I wouldn't think it would make a difference on concrete either, except, everything I have read warns of even laying wood floors on concrete, without the proper preparations wood floors don't do real well on concrete.
This being a new build I would be more concerned with the moisture content in the concrete and how that will effect the floor.
Did you witness the preperation of the concrete, what was the moisture content, I don't want to scare you, but this would be an additional concern IMHO.
Mark
Old 08-04-2011, 04:01 PM   #4
I was not present at the time the floor was laid, or prepped. How long would it take for the moisture content of the slab to drop to an acceptable level?
Old 08-04-2011, 05:19 PM   #5
i do know some engineered flooring is ok to glue down on concrete but have never did it personally.
solid hardwood is never supposed to be installed on concrete.
Old 08-04-2011, 05:29 PM   #6
I will correct my self. In the contract it specifies "engineered oak flooring". So it "should" be ok. But as for the directionality of the flooring there is absolutely no reason it must be laid front to back versus left to right(other than not wanting as much waste).
Old 08-04-2011, 06:04 PM   #7
woodman58's Avatar
There is no reason the floor could not be run any way you want it. You could change direction any where you wanted to on concrete. I have been installing hardwood for 28 years. I think the contractor did not tell the installer about you preferance.
woodman58 is offline   Reply With Quote
Old 08-04-2011, 06:22 PM   #8
Thanks for all the help. I guess they will be prying up the floor and replacing it. Good thing it's not my money they are spending for all of their mistakes.
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 02:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
