Direction Problem Of Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-24-2008, 05:06 PM   #1
direction problem of wood flooring
I'm building a new house and my floor joist are running the same direction that I want to run the wood flooring, can I use 2" x 4" sleepers every 16 inches between the floor joists & nail the 3/4" tongue & groove boards into them? I would prefer to do this rather than installing another level of sub-flooring.
sunset is offline   Reply With Quote
Old 01-24-2008, 07:58 PM   #2
4th generation DIY'er
mhuyser's Avatar
One solution would be to install a your tongue&groove onto the subfloor at a 45-degree angle; this isn't the direction you originally wanted but it's a simple and unique design element.
If you still want the original direction, you might be able to get away with an extra subfloor for support that will certainly be less thicker than a 2x4.
Either way, I'd make sure to consult an engineer whenever you want to make changes that affect structural integrity.
mhuyser is offline   Reply With Quote
Old 01-25-2008, 06:08 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,058
Ayuh,..... I gotta be missing something here,.....
This Wood Flooring,... This isn't the finish floor is it,..??
Old 01-25-2008, 06:36 AM   #4
Thanks for your inputs. I actually got an answer from someone at the National Wood Flooring Association that makes sense. He said:
"Without installing another layer of subfloor material the option is to install 2” x 6” braces every 2’ between the floor joists."
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood Flooring etc emptee A Flooring 1 08-15-2007 10:57 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 01:04 PM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 06:21 AM
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 02:20 PM
