Direction Of Planks?? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 10:30 PM   #1
Direction of planks??
I am planing on installing a floating laminate floor in an old house that has about an 1.5" slope in 18'. For descriptive purposes I the slope is E to W. I was planing on laying the planks N to S, as this is the longest wall in the room. Does it matter which way the planks are laid, with the sloping floor.
bbfrs1 is offline   Reply With Quote
Old 06-02-2012, 03:16 PM   #2
Remodeling Contractor
the floor should be level first. If that is too much then run the planks perpendicular to the slope.
Old 06-07-2012, 11:25 PM   #3
If its going to a drain I'd advise against putting wood there
Toilet Bowl is offline   Reply With Quote
Laminate Flooring Direction canadiandude Flooring 4 03-03-2012 04:19 PM
Deck framing for mitered deck planks corners jim-in-ga Building & Construction 11 12-08-2011 04:37 PM
peel and stick vinyl wood planks - subfloor prep questions bonanz Flooring 11 12-07-2011 07:41 AM
Hardwood flooring installation - Should these planks not be installed? htabbas Flooring 8 11-30-2011 07:50 PM
Nailing down engineered wood planks ? Flt_Simulation Flooring 2 05-14-2009 04:36 PM
