Direction To Lay Hardwood Flooring In House With Large Windows - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 08:00 PM   #1
Direction to lay hardwood flooring in house with large windows
I enter my home into a large open room, first foyer, to the left dining room and directly ahead a large great room. Then I'm facing a wall of 18' windows... very bright.
Do I lay the floors with all the short ends across the windows and the long ends on the side? So they will look like they are all pointing towards the windows.
What do I do with a long hall off the right side of this giant room? Just make a turn so the long ends are on the wall instead of it looking like a ladder when walking down the hall.
I've laid many floors but never hardwood.
Novice from New Orleans
rosieoutlook is offline   Reply With Quote
Old 04-09-2012, 08:11 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Generally, hardwood is laid parallel to large windows. Although, there are other factors that need to be taken into consideration (room dimensions, shape, etc.).
- Build Well -
Old 04-09-2012, 08:25 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
What? What if there's windows on two walls? Windows have little or nothing to do with how the planks should be installed. The main thing is the direction of the joists and how the areas are orientated.
Hardwood & sunlight = fade. Have you made any accommodations for that?
Jaz
Old 04-09-2012, 10:10 PM   #4
Please re-read my post; I stated in clear english what is the "general" concept (for elongated rooms with primary lighting along (1) longest length wall) - BUT that there are other factors to take into consideration, and I listed "2" of them as an example...
- Build Well -
Old 04-09-2012, 10:22 PM   #5
I am planning on updating the windows with E-glass that prevents fading. They are already double insulated but I was upgrading them to save money on utilities. It gets hot down here.
I also read an article about running them parallel to large windows. Why is that done. It would be fairly easy to do that since I'm ripping up all floors. That would make the hall blend right in. Only difference would be they will look a little odd at the entrance. At least it would all be going in one direction. I don't know if I've ever seen them run that way at the entrance.
Old 04-09-2012, 10:25 PM   #6
I agree with the others. The flooring should be laid perpendicular to the floor joists.
RhodesHardwood is offline   Reply With Quote
Old 04-10-2012, 10:27 AM   #7
How do I know which way the floor joists are going on a post-tension cement slab?
Old 04-10-2012, 11:34 AM   #8
Tileguy
JazMan's Avatar
Rewards Points: 388
Well, obviously you now go to the next most important criteria which would be the way it would look best to you, to include how the open space lays out and the large windows may play into your decision. When doing several rooms you'll also need to consider how the overall job will turn out.
I had assumed you had a wooden subfloor since you're installing hardwood. You must be installing engineered hardwood, yes? Or will you building up the floor and go with solid hardwood? Have you decided yet and have you taken moisture reading?
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
rosieoutlook (04-10-2012)
Old 04-10-2012, 04:16 PM   #9
I'm installing engineered hardwood on a post tension slab now 15 years old. I'm beginning to think, from all of the comments, parallel to the large windows would be best. All wood strips in every room in the home will be going in one direction. To consider the problem at the entrance, the parallel strips will not have the traditional look. I may decide to add a natural slate entrance area to handle that problem.
Old 04-10-2012, 05:15 PM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
I saw a episode on this old house, they put down the floor same direction as the porch in front of the house regardless of the joist direction.
JetSwet is offline   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
Old 04-10-2012, 07:42 PM   #11
That would be in the direction of the wall of windows. Everything is starting to seem like that is the best way to do it.
Thanks everyone, you have all been a big help.
Old 04-10-2012, 07:57 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 388
Yes, that's because the joists will almost always be running the short way, so the hardwood should go the long way. Not because of any windows, but because you want the hardwood to go perpendicular to the joists. Having said that, if the homeowner needs to run the planks in the same direction as the joists, you should add an underlayment per manufacturer's directions. But we've learned this situation has no joists so it's now academic.
Jaz
rosieoutlook (04-11-2012)
Tags
easy click , engineered wood flooring , floating floor
Direction of hardwood floors DBounlom Flooring 2 10-08-2011 06:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Installing nail fin windows - house wrap and t 111 siding DirtDog Remodeling 3 03-16-2011 11:59 PM
Which direction to install laminate flooring - Floorplan attached oONightFireOo Flooring 8 01-31-2010 03:01 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
