Which Direction To Lay Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 05:51 PM   #1
Never too old to learn
Dudester60's Avatar
Which direction to lay hardwood
Hi
I'm getting ready to install 3" wide maple hardwood floor in 3 bedrooms and the adjoining hallway. My floor joists run the length of my hallway, as well the bedrooms. My floor is 3/4" plywood, and my joists run 12" center. For cosmetic reasons, we'd like to have the maple hardwood run the length of the hallway as well as in the bedrooms. I want the transition from the hallway into the bedrooms with no joint at the thresholds, but rather flow into each room. My question is this, is it REALLY necessary for the hardwood floor to run perpendicular to the joists. I do realzie that I'll have to add a spline for one of the bedrooms, in order to change direction for the bedroom across the hall.
Also, when I removed the parkay flooring from the hallway (bedrooms have carpet) which was extremely difficult to remove, and in the process, I damaged the top of the existing plywood sub floor in some places. Is there anything I can use to repair the top of the sub floor to make it smooth again.
I plan on screwing down the sub floors to remove any existing squeaking that I have, + I want to add felt paper/roofing paper to the floor prior to installing the hardwood. Any suggestions ? Can I run the hardwood in the same direction as the joists ?
Dudester60 is offline   Reply With Quote
Old 09-10-2011, 05:58 AM   #2
woodman58's Avatar
You can run the wood with the joist but you will end up with squeaks over time. By laying with the joists this allows the floor more movement and therefore letting the cleats or staples work loose.
woodman58 is offline   Reply With Quote
Old 09-10-2011, 09:34 AM   #3
Dudester60's Avatar
Thanks woodman58, that's what I was hoping to hear. I plan on using staples, which I've read holds better in the long run that cleats or nails.
In the bedrooms, there is very little traffic, therefore I'm not worried about squeaks becoming a problem there. As for the hallway, I was thinking of installing cross blocks between the joists from the underside, which would allow the hardwood floor to be nailed into something solid, rather than just the plywood. I plan on making sure there are no squeaks at all on the plywood subfloor before I start installing the hardwood floor.
Thanks again, and if you have any more advice, I sure would appreciate it.
Old 09-11-2011, 09:12 AM   #4
Dudester60's Avatar
I read somewhere in this forum, that if you have a " plywood over the joists, you can go in any direction, without worrying about the hardwood cleats coming loose. Seeing that I do have a " plywood to work on, I think I'm going to take a chance, and run the hardwood in the same direction as the joists, which are 12" center. Once again, going perpendicular will make the hallway look like a rail road track, which isn't the look we want.
However, I still open to suggestions or tricks that I can apply to the job.
Thanks.
Hardwood Floor - Reversing Direction PhilC Flooring 14 04-07-2010 03:23 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
Solid Hardwood direction daxinarian Flooring 6 09-18-2008 02:13 PM
Direction of Hardwood floors kprice General DIY Discussions 2 03-12-2008 08:36 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 08:50 PM
