Old 11-12-2009, 08:03 PM   #1
direction of laminate flooring
Hi all
i am in the pre-planning stages of purchasing/installing laminate wood flooring. since i cannot afford to do my whole house at once, i will end up doing two rooms for right now.
i have two rooms that are off of the hallway. i will be doing the hallway later but for now, i need to know which direction to run my flooring slats. should the hallway slats run long ways and then the bedrooms the opposite direction?
i am attaching a floor plan of the rooms/hallway so you can see what im saying.
now, the hallway, living room and dining room all run together meaning i have no walls to divide each room up. the bedrooms are the only rooms that have a door/wall to separate them. with that, whatever direction the hall runs, should the rest of the house run the same way?
again, i am only installing the 2 bedrooms for right now. just trying to plan ahead.
reds_21 is offline   Reply With Quote
Old 11-12-2009, 08:48 PM   #2
ArmchairDIY's Avatar
I would run the hall and other rooms the same direction. If your doing the bedrooms you could change the direction in those if you want.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself!
ArmchairDIY is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
What would be the best direction for my laminate flooring? dotrn Flooring 1 06-29-2009 02:01 PM
