-   -   direction of laminate flooring (http://www.diychatroom.com/f5/direction-laminate-flooring-57078/)
reds_21 11-12-2009 08:03 PM
1 Attachment(s)
Hi all
i am in the pre-planning stages of purchasing/installing laminate wood flooring. since i cannot afford to do my whole house at once, i will end up doing two rooms for right now.
i have two rooms that are off of the hallway. i will be doing the hallway later but for now, i need to know which direction to run my flooring slats. should the hallway slats run long ways and then the bedrooms the opposite direction?
i am attaching a floor plan of the rooms/hallway so you can see what im saying.
now, the hallway, living room and dining room all run together meaning i have no walls to divide each room up. the bedrooms are the only rooms that have a door/wall to separate them. with that, whatever direction the hall runs, should the rest of the house run the same way?
again, i am only installing the 2 bedrooms for right now. just trying to plan ahead.
ArmchairDIY 11-12-2009 08:48 PM
I would run the hall and other rooms the same direction. If your doing the bedrooms you could change the direction in those if you want.
