Old 10-04-2011, 04:47 AM   #1
Direction of hardwood floors
Hi all. Can I get some input on the direction that my new hardwood floors should be laid? It is slightly complicated, but I am laying engineered wood on top of existing solid hardwood. One of the reasons is because the previous owner made extensions to the house and did not extend the old solid hardwood. I believe the old solid hardwood is laid perpendicular to the joists. Should I lay the engineered wood parallel to the existing solid wood? The floor guy I got to help me said to lay the engineered wood perpendicular to the existing solid wood. The problem that I have with that suggestion is that the floors will run against the length of the house. If I follow the advice, I have a hallway that I would be laying boards the short width section instead of flowing with the longer length section. Assuming the house is rectangular, shouldn't I be laying boards parallel to the longer side of the house? Thanks.
DBounlom is offline   Reply With Quote
Old 10-06-2011, 04:31 PM   #2
I think if your sub-floor is sturdy it doesn't make much of a difference. It's a personal preference.
MsFinnegan is offline   Reply With Quote
The Following User Says Thank You to MsFinnegan For This Useful Post:
Thurman (10-09-2011)
Old 10-08-2011, 07:37 PM   #3
Okay thanks.
Which direction to lay hardwood Dudester60 Flooring 3 09-11-2011 10:12 AM
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 08:58 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Direction of Hardwood floors kprice General Discussion 2 03-12-2008 09:36 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
