Which Direction Do You Run Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-22-2008, 08:58 AM   #1
which direction do you run laminate?
Looking at the Armstrong Grand Illusions Cabrueva laminate. We will be doing a foyer, leading from our front door, down an 8 foot hallway into our country kitchen, which runs the back of our house and to the left of the foyer. We've been told to start at the "short wall" in the kitchen, furthest from the foyer, and run back towards the foyer area, so that you would be looking at the lengthwise (parallel) boards as you walk in the front door. However, we have also been told to run it opposite the floor joists, which would mean running it the opposite direction, seeing the boards perpendicularly (left to right) as you walk in the front door. Is there a PROPER way to do this or just eyeballing it for the right "look"?
wheatiesb1 is offline   Reply With Quote
Old 02-22-2008, 09:00 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
In hardwood flooring installations, the boards are run perpendicular to the floor joists for nailing purposes. Laminate is not hardwood, and is generally installed floating or glued to the substraight or subfloor.
The basic rule of "thumb" for wood-look laminate is: Board segments should be placed to be parallel towards the greatest natural light source.
- Build Well -
Old 02-22-2008, 09:14 AM   #3
Rewards Points: 324
I have heard this multiple times, does anyone have any reasoning for this?
tigerbalm2424 is offline   Reply With Quote
Old 02-22-2008, 12:45 PM   #4
Rewards Points: 682
How about aligned parallel to the straightest wall? So the pieces are in proper alignment even if some of the walls are crooked?
darsunt is offline   Reply With Quote
Old 02-22-2008, 01:20 PM   #5
The exception would be if you have a longer rectangular area, or a hall-way. In those circumstances, you would want to run the segments lengthwise, parallel to the long walls.
- Build Well -
Old 02-22-2008, 01:24 PM   #6
Natural lighting does not illuminate the floor from above, like artificial lighting does.
Natural lighting comes in from the sides of a home (windows/doors). Because of that angle of lighting-illumination, the finish, design, and details of wood-like laminate flooring materials are more visible.
In this case, you have material with a picture of wood grain finish. You have lines where the segments are placed next to eachother. It is best to have these working, along with the natural light, in order to mimic the appearance of an actual hard-wood flooring.
- Build Well -
Old 02-22-2008, 01:42 PM   #7
For an easier installation, I run the laminate perpendicular to the doors and closets. When I get to the row with a door jamb, the first piece I lay down is the piece that slides underneath the jamb. Once I'm satisfied with that piece, I continue in both directions.
adave is offline   Reply With Quote
Old 02-24-2008, 06:30 PM   #8
Floorwizard's Avatar
When you run the wood or lam parallel with the light, then you only accent the short sides of the boards.
running the other direction highlights the longer sides and some do not like that look.
Floorwizard is offline   Reply With Quote
Old 05-05-2008, 11:26 PM   #9
Thumbs down
Armstrong Grand Illusions WARNING/COMPLAINT/DISILLUSIONED
Before you buy, read my posting at:
http://ths.gardenweb.com/forums/load...5722924.html?5
I do not recommend Armstrong Grand Illusions.
magicalflowers is offline   Reply With Quote
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 08:07 AM
Laminate on side of steps and direction 83trekker Flooring 4 02-20-2008 04:42 PM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
