Differing Floor Heights - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 05:59 PM   #1
Differing floor heights
I'm working on an addition to my kitchen, the problem is that there is a 1/4 inch difference in height between the new floor (low) and the old (high). My first thought was to simply get 1/4 ply and lay that down over the new floor to match the heights, but that will throw off the the height of the floor where it hits the transition to the pantry and the exterior door.
The next thought was to sand down the the plywood of the old (high) floor to ramp to the level, but I don't know that I'd be able to get it smooth- plus there are cabinets that have to bridge the 2 floors.
Any help or ideas are greatly appreciated.
Al
lokisince89 is offline   Reply With Quote
Old 09-13-2011, 06:02 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can not realistically sand the plywood in that fashion and that amout.
What will be your final floor covering?
Old 09-13-2011, 06:09 PM   #3
The final covering will be 8 1/2 wide tongue & groove hardwood.
Old 09-13-2011, 06:17 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why will it?
Old 09-13-2011, 06:32 PM   #5
The transition to the outside door is raise 3/4 inch above the sub floor- that's the thickness of the new flooring. When laid flat on the sub floor now it slides under the transition perfectly. With the 1/4 ply it butt the transition piece instead. The pantry transition is a single piece of marble ( the pantry floor is tiled) that 1 inch high and beveled on the edges to 3/4 so it would meet the original floor level. Now if I put down the 1/4 plywood the bevel would be sunk under the overall level of the floor.
Al
Old 09-13-2011, 06:41 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well then I would say you are faced with a dilemma.
I suppose replacing the marble and raising the door are out of the question?
Old 09-13-2011, 06:43 PM   #7
I don't think so.
differing opinions by two electricians timbo59 Electrical 18 09-01-2010 02:44 PM
Help With Differing Opinions Re Prime Or Not By Painting Contractor jaylin Painting 8 11-23-2009 03:42 AM
Differing size of Baseboard Trim offered at the Hardware store pk1023 Carpentry 7 02-23-2009 05:04 PM
Molding across rooms with differing floors 4help Building & Construction 2 01-09-2008 05:10 AM
