Determining Floor Flex For Tile Project - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 01:08 PM   #1
Determining floor flex for tile project
I am hoping to replace a linoleum floor with a tile one. However, our house has POST & BEAM construction with 2" x 6" TONGUE & GROOVE subfloor spanning the beams and I am wondering if we may have too much flex in the floor for tile.
The floor SEEMS very solid, but the 2" x 6" tongue & groove car decking subfloor spans 4" x 10" beams (supported by 4" x 6" posts on good concrete foundation) with a 60 inch span between the 4" x 10" beams (face to face). There is currently particle board on top of the car decking, which I understand I'll have to cut out and replace with 3/4" plywood (or thicker???), and I'm planning on using thinset and 1/4" Hardibacker on top of that. Will this be rigid enough? Should I use thicker plywood and/or 1/2" Hardibacker? Will I still have too much flex from the 60" spans? How can I tell?
george779 is offline   Reply With Quote
Old 05-09-2012, 07:01 PM   #2
Thadius856's Avatar
Rewards Points: 504
This is almost exactly my situation, except that I'm working with 2x6 TnG over 4x8 on 4'.
How pertinent. :D
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 05-10-2012, 06:01 AM   #3
Rewards Points: 1,580
Might try:
http://www.johnbridge.com/vbulletin/deflecto.pl
bob22 is offline   Reply With Quote
Old 05-10-2012, 04:15 PM   #4
Originally Posted by bob22 View Post
Thanks for sharing that.
RhodesHardwood is offline   Reply With Quote
Old 05-10-2012, 07:29 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
The only thing you can put over your 2x6 T&G is hardwood flooring, tile is a hole nother animal when it comes subfloor strength.
Cement board holds no strength it's just a filler for your tile and a preventative for water damage if tile fails.
When I install tile I use 1" of ply if I have the hight for it but no less then 3/4" if not from joists up.
You might get away with 1/2" if staggered ply correctly.
JetSwet is offline   Reply With Quote
My Custom In-Wall Entertainment Center Project! With lots of photos!! joseph011 Project Showcase 12 01-03-2011 01:43 PM
my floor refurbish project Knucklez Project Showcase 28 08-10-2010 08:14 AM
Building a deck project zzzz General DIY Discussions 3 05-06-2008 07:56 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
My basement finishing project DIY4EVER Project Showcase 6 02-18-2008 08:21 PM
