Delta-FL Under Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 02:51 PM   #1
Rewards Points: 508
Delta-FL under tile
I posted this question on another forum, but no one could give me anything more than vague gut feelings:
Any thoughts on the following layers?: Delta-FL, 1" 60 psi foam (overkill?), 3/4" Advantech, Laticrete Multipurpose Pro, Nobleseal TS, Laticrete Megabond, mesh-backed penny-round porcelain tile.
This installation is going over a basement slab with no insulation and no poly vapor barrier. The rest of the basement will be Delta-FL, 1" 25 psi foam, 3/4" Advantech, and carpet. The carpeted area is the area where I'm worried about the potential for surface water from the floor-wall joint (I'm already replacing the perimeter drainage tile and putting a waterproof membrane on the exterior of the foundation).
The tiled area will be in an area of the basement that is mostly above grade, so perhaps I could put the foam directly on the slab, eliminating the Delta-FL in this area. Would you run tapcons through the Advantech and the foam? Is PL 300 necessary?
benjamincall is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
