Old 08-23-2010, 02:52 PM   #1
Decoupling membrane
Hi I am having a new floor laid - doing what I can myself- but am not tackling the 30sqm of concrete and screed over underfloor heating.
Planning to lay some travetine tiles once flooring is done - but really unsure if need a decopling membrane. It will add nearly £4-500 to job - which I can't really afford- how essentil is it?
americasmiles is offline   Reply With Quote
Old 08-24-2010, 12:03 PM   #2
Stuck in the 70's
Blondesense's Avatar
Decoupling membrane
Keep in mind I'm not an expert, just spend too much time here on the boards.
My understanding is tile will expand and contract at different rates than concrete. A decoupling membrane allows this expansion/contraction to happen without damage, otherwise this can cause tile and grout to fail, crack, and/or come loose.
This is more of an issue in colder climates than in temperate climates. Also, adding the underfloor heating will increase the temperature fluctuations and so will increase the chance of problems.
Are you a betting man?
Personally, If I were adding in-floor heating of any sort, I would go with a membrane.
Old 08-27-2010, 12:55 AM   #3
Decoupling membrane
Blonde is right use Ditra.
gjjr2001 is offline   Reply With Quote
Tags
decoupling membranes
Vent dryer through flat membrane roof Vince Rosati General Discussion 6 11-02-2008 03:11 PM
PVC Membrane question frankburns Roofing/Siding 15 09-18-2008 03:04 AM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 09:41 AM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 06:16 PM
Shower membrane mc52 Building & Construction 2 01-27-2007 10:59 PM
