-   -   Decorative Concrete Flooring: Creating Molds Brainstorming Needed (http://www.diychatroom.com/f5/decorative-concrete-flooring-creating-molds-brainstorming-needed-164911/)
soapage 11-27-2012 06:21 PM
At current Job I need to put together about 600 square meters of some custom made interlocking removable flooring. I will give you a brief overview of what I currently have. Pictures Below
- The concrete slabs need to be floating. Water will drain between the joints and channel through the finishes slab below. They will sit on either concrete "rails" or "supports"
- The client needs the concrete slabs to be removable, but at the same times be locked by some sort of support. Note: When hurricane sandy hit us marble slabs were detached from elevated pool deck landed on the parking lot below.
- All the material must be concrete
PICTURES
Below is a small slab sample with a sample "rail". The rail would be secured to the concrete flooring on its flat base. The slab is the larger piece. As you can see the notches would allow me to slide the concrete slab on rails on either side.
http://i.imgur.com/gFagl.jpg
Below is a picture of how the slab would slide along the concrete rail.
http://i.imgur.com/ljtes.jpg
Another angle
http://i.imgur.com/YhyJx.jpg
Another angle
http://i.imgur.com/UoKEz.jpg
Once the rails are secure to the concrete floor you would be able to slide the slabs along the rail from one end to the other.
Problems with this system
- you would need to install the slabs from one end, making removal of a single slab tedious.
The architect later proposed a system where the floor format would be as pictured below. I will start working on a system for this format, but it seems to be very difficult. Note that the slabs would need to be either 1.6x.8 or 1.2x.6
http://i.imgur.com/qwdnF.jpg
Canarywood1 11-27-2012 07:54 PM
How do you intend to keep the water that drains between the rails from freezing???
soapage 11-28-2012 04:47 AM
I live in Dominican Republic.... freezing isn't and issue.
