Deck Stain - Flooring - DIY Chatroom Home Improvement Forum
Old 06-03-2014, 09:18 PM   #1
Rewards Points: 874
Deck Stain
Got two quotes for someone to stain our deck. One guy said he would use a foam applicator with two coats and the other said he would use a pump spayed with one coat. Which would give a better job? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 06-03-2014, 09:35 PM   #2
Rewards Points: 92
The one who said he would also back brush. Ron
ront02769 is offline   Reply With Quote
Old 06-03-2014, 09:42 PM   #3
Rewards Points: 874
Lol.......And what is back brush
Old 06-03-2014, 10:00 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
Preferred method. The pad would be second best. Verify if the stain your using requires one coat or two.
Pump sprayer is ok, if messy, as long you work it into the wood after spraying. With something like a brush.
Jmayspaint is offline   Reply With Quote
Deck Stain Help bigmike53 Painting 13 05-29-2013 02:49 PM
used house stain instead of deck stain on a deck yura Painting 5 07-10-2012 05:29 PM
Removing stain from deck machouinard Painting 20 09-08-2011 10:12 PM
Spraying a deck stain hdansjr Painting 3 04-22-2009 12:36 AM
