Dark Bamboo Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 12:53 PM   #1
Dark bamboo flooring
What is the best way to clean bamboo flooring?
Kashka is offline   Reply With Quote
Old 04-21-2013, 02:33 PM   #2
Vinegar and water.
skipoff is offline   Reply With Quote
Old 04-21-2013, 02:34 PM   #3
You may have to dry it though to prevent white water spots.
Old 05-12-2013, 08:31 PM   #4
For me, I use Murphys Oil Soap (as long as your floor is finished). It really gets the grime off and has a pleasant smell to it.
But if you are looking for a homemade variety----- in a bucket mix 1/2 cup of white vinegar per one gallon of warm water. Dip in your mop and squeeze out the excess and mop your wood floors. No rinse is required
good luck and happy cleaning
urbaneve is offline   Reply With Quote
Old 05-12-2013, 10:26 PM   #5
Never ever ever use murphys oil soap on hardwood floors. Only clean wood floors with a product that does not leave any residual on the floor. Murphys does.
The Following User Says Thank You to skipoff For This Useful Post:
Awoodfloorguy (05-13-2013)
Old 05-13-2013, 09:51 AM   #6
Rewards Points: 264
I always recommend Bona wood floor cleaner to our clients. Murphys oil soap is about the worst thing you can use to clean wood floors. Bona even makes a spray mop that is like a wet swiffer, it makes cleaning really easy.
Awoodfloorguy is offline   Reply With Quote
Old 05-13-2013, 10:58 AM   #7
Rewards Points: 3,628
+1 for Bona
Canarywood1 is online now   Reply With Quote
Old 05-13-2013, 11:20 AM   #8
Too Short? Cut it Again!
Isn't their a protective poly finish over the bamboo? Something like Murphy's will turn it into an ice rink.
My Bamboo Flooring Experience schraggyj Flooring 3 08-21-2011 05:24 PM
Bamboo Engineered Flooring/ Expansion Joint Annielaurie Flooring 1 04-16-2011 11:24 AM
Installing Bamboo Flooring with Brad Nailer? aaks38 Flooring 3 11-04-2008 09:11 AM
a few questions about bamboo flooring installation bostonmike Flooring 2 01-19-2008 08:06 PM
what type of nail gun for bamboo flooring? matchley Flooring 4 12-26-2007 03:47 PM
