Damp Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 09:20 AM   #1
Question
damp basement
Hi to all from a nube and thanks for your help
I am wanting to install cork flooring in my basement , but am concerned about concrete dampness.
Can I put poly vaper barrier over the floor and up the out side walls to help in this area??
Thanks john
John W Lee is offline   Reply With Quote
Old 08-20-2012, 01:55 PM   #2
Advice from Ameri-Dry Guy
Yes, you can always put down some sort of plastic/poly or even go to the extent of a drain board, which you can find at any Home Depot ask a flooring expert and they can tell which would suit your needs.
Ameri-Dry Guy is offline   Reply With Quote
Old 08-20-2012, 03:14 PM   #3
Rewards Points: 264
A standard underlayment should be sufficient for this.
Awoodfloorguy is offline   Reply With Quote
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 03:11 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Concrete Porch Above Basement is Damp tholley23 Building & Construction 0 11-30-2010 07:03 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
