Damp Area On Floorboards - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2014, 03:15 AM   #1
Damp area on floorboards
Hello all,
I have recently pulled up some carpet and found a damp area on the floorboards in the passageway as can be seen in the pictures. I am not too sure what is causing it, but it is damp to touch.
The ceiling above is completely dry. I have cut a piece of the board and the underside of the timer is dry as well, with no water or dampness visible on the soil beneath. It looks as though the dampness is only in the top half of the timber as below the groove, it looks dry.
It is only in the one spot in the house, as all other rooms are fine. It has been there the last few months and doesn't seem to be drying.
Thank you in advance for any ideas on what it could be.
Damp area on floorboards-20140509_170107-copy.jpg   Damp area on floorboards-20140509_170115-copy.jpg   Damp area on floorboards-20140509_170124-copy.jpg
adaniele is offline   Reply With Quote
Old 05-09-2014, 06:24 AM   #2
Rewards Points: 144
Have any pets?
mako1 is offline   Reply With Quote
Old 05-09-2014, 07:27 AM   #3
Rewards Points: 14,304
Under floor heating?
Slab, crawl space, basement under it?
Any access under it to take a look?
Pressed to on a piece of toilet paper in that spot to see if it gets wet or it's just smooth where someone tested a spot or poly?
Old 05-10-2014, 04:54 PM   #4
Thanks for the responses,
I'm guessing its an oil stain of some sort, as the toilet paper didn't get damp and I've also had a further look below with a mirror and everything looks dry
Swing set play area frame out... 68MHJCs Building & Construction 10 05-14-2013 12:32 PM
Installing floating wood floor, need advice on fixing uneven floorboards armand11 Flooring 0 05-06-2013 11:27 AM
What to install first: 8x8 post OR paver area cgilbert Landscaping & Lawn Care 1 03-18-2011 06:21 PM
Insulating area under roof... BlueBSH Building & Construction 10 11-08-2010 12:43 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
