Damaged Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 03:11 PM   #1
Damaged Tile
Has anyone ever had to remove a damaged porcelain tile from Ditra?
hompac is offline   Reply With Quote
Old 02-16-2009, 09:01 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 346
Is this a survey? I haven't have had to do that.
Jaz
Old 02-19-2009, 06:36 AM   #3
nope but i have removed it from 3/4" ply flooring,,, do i win a prize ? ? ?
gimme a 4" grinder & diamond blade & we'll remove anything
yesitsconcrete is offline   Reply With Quote
Old 02-19-2009, 06:52 AM   #4
I'll think I take all the prizes. I intentionally damage them then remove them.
I am not a tile guy I but have had to remove portions of porcelain beneath cabinets to install a central vac device referred to as a vac pan. This item is installed in kick plates of cabinets and requires a cut out in the kick plate a swell as a 2" pipe run through the floor about 6-8" behind the kick plate.
I generally cut along the porcelain grout line and then cut from the mid area of the tile to the grout line with my diamond cutting blade on a small hand grinder. Then lift the cut edge from the middle so as not to damage the adjacent tile and it pops up clean.
If you are not using the diamond grinder, when I am dealing with tile or plaster or hardened paint, I always etch or pre drill my pattern if chiseling or sawing before I cut in case a crack forms and needs a path to follow. If you want to drill the porcelain to create a path you will need a bit rated for glass. I use one from Mibro and it is spade shaped. Very useful.
Do I win?
Chemist1961 is offline   Reply With Quote
Old 02-19-2009, 06:55 AM   #5
Do you have in floor heating?
Old 02-19-2009, 07:27 AM   #6
ccarlisle's Avatar
We do this using the Fein Multimaster oscillating tool with anumber of blades...no major dust. Cut the grout out, then break the tile with a hammer, remove. Cut the Ditra right down to the substrate remove it and replace it with a new piece. Takes about 20'...
A bit messy but that's OK.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 03:17 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
