Damaged Subfloor By Tub - Flooring - Page 4 - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 02:29 AM   #46
Rewards Points: 866
Another Bad Spot
Now that I am prettty well ready to put the new subflooring section in and lay down some Hardy Board, I am wondering what to do about the tub.
Here is a pic of the overall job (including all I cut back that wasn't necessary) and a couple of close ups of the spot. Am I being penny wise and pound foolish by not calling in some pros and having the tub pulled or is it good enought to remove the bad wood up to the tub and a couple of inches under it with a chissel?
damaged subfloor by tub-001.jpg   damaged subfloor by tub-br-floor-mar-11-028.jpg   damaged subfloor by tub-br-floor-mar-11-031.jpg
Klawman is offline   Reply With Quote
Old 03-11-2013, 05:01 AM   #47
DIY staff
Rewards Points: 7,174
You will be fine patching that and not removing the tub----
When the time comes for a complete remodel --then do the tub----
Old 03-11-2013, 07:32 PM   #48
Rewards Points: 866
With that for encouragement, I went and looked under the last tile, which was removed in the last photos. Whoopee! That section of the bottom of th tub is pretty well open and I can cut back under the tub a bit and remove any suspect wood.
It will be a little tight with that block running from joist to joist in the way, but I don't want to disturb it.
The Following User Says Thank You to Klawman For This Useful Post:
oh'mike (03-11-2013)
Tags
bathroom , leak below tub , tile
How do I remove part of the damaged subfloor? ChEMom Flooring 17 07-15-2011 12:28 PM
Water damaged underlay kimchee Carpentry 1 05-16-2011 08:20 AM
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-01-2010 11:21 PM
Damaged fascia (Pics) timcsi Roofing/Siding 7 09-15-2009 10:00 AM
How to Repair Spot Damaged Carpet jrguy Flooring 1 08-25-2009 06:45 AM
