Old 10-21-2009, 02:40 PM   #1
Default cutting tile
i have to cut a tile for my bathroom floor,its just 1 tile with a circle for around the toilet flange.I dont want to spend money on something that i might not use again as its for just 1 tile.Im thinking of getting a glass cutter,scribe the circle,cut the tile in half and then break off the rest with plyers or something.Will this work or is there a better way?
thx
ron0805 is offline   Reply With Quote
Old 10-21-2009, 10:13 PM   #2
you could just use tile nippers. A little bite at a time will work fine. Not much to by one.
More On This Topic
Hi, I’m Faith and I’m here at Flat Fork Studio, and I’m going to show you how to cut a tile using a handheld tile cutter. Basically, what you do is you lay your tile out- say if I want to cut this tile in half- I’ll lay my tile... Read More »
Hi, this is Cheryl from Expert Village and I'm going to be teaching you how to make fused glass jewelry today, so check it out. You can use these little tile clippers here, and just cut it out, cut out a little circle. And, it goes superfast. Now this is... Read More »
One of the biggest headaches for do-it-yourselfers in the bathroom is cutting ceramic tile to fit around pedestal sinks and around toilets without breaking the tile. The inside circle cut may seem intimidating, but it actually can be accomplished with a... Read More »
Hi! This is Brian Carter on behalf of Expertvillage.com. I have 10 years of ceramic tile installation experience. Today I am going to show you how to make an exterior circular cut. Okay we have our mark for our outside circle cut. What we are going to... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m here to show you some basic tools that you want to have on hand when preparing to do your mosaic tile project. First we have a caulk gun, Liquid Nails adhesive. This is one type of... Read More »
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 09:05 PM
Cutting Narrow Tile Pieces MrBill_DIY Remodeling 2 08-17-2008 02:33 AM
Cutting Porcelian Tile without chips BruceStone Building & Construction 3 02-01-2008 06:33 PM
Cutting Tile rookie1 Remodeling 9 10-22-2007 06:25 PM
cutting 18" tile bobloj Flooring 6 10-20-2007 12:03 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
