Old 01-16-2013, 07:25 AM   #1
Cutting tile
I'm going to be laying new tile in the bathroom floor. I have to make a few cuts in the tile. I have put up tile backsplash in the past and I used nippers. Wich was a joke but only had to nip a few. U do not want to purchase a wet saw cuz of the price. I have a dremel tool was wondering if anyone knew of a good bit to use to cut a few tiles?
bwavem is offline   Reply With Quote
Old 01-16-2013, 07:59 AM   #2
Cutting tile
I'm not familiar with using a Dremel to cut tile, but I can't imagine using any possible Dremel bit to make the kind of cuts you'll need for floor tile.
You can get some pretty cheap tile saws that will work just fine for small jobs.
http://www.harborfreight.com/4-inch-...tray-3733.html
If you want to go even more cheap, just use an angle grinder with a diamond blade.
http://www.harborfreight.com/4-1-2-h...der-95578.html
Depending on the tile you're cutting a tile cutter might work, but in my opinion the cheap ones are maddening to use because they crack as many tiles as they cut correctly, especially porcelain.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
oh'mike (01-16-2013)
Old 01-16-2013, 08:03 AM   #3
Super Moderator
Cutting tile
Rent if you need a saw for only a few cuts----some stores offer cutting service---but the time wasted running to the store for your cuts will drive most folks to rent or buy.
Look on Craigs list for a cheap saw--then re-sell it when done----
Old 01-16-2013, 10:09 AM   #4
Cutting tile
If you go to Dremel's website
Centex2011 is offline   Reply With Quote
Old 01-16-2013, 10:13 AM   #5
Cutting tile
They should have a list of accessories. I know I have seen a diamond bit for cutting tile in their list. I would second the use of an angle grinder and a diamond blade. I used one for cutting tile and had no problems. Just make sure you draw your line on the tile and that you have a steady hand.
Old 01-16-2013, 10:14 AM   #6
Cutting tile
Ok thanks everyone
The Following User Says Thank You to bwavem For This Useful Post:
Tile Cutting chade64 Flooring 4 01-16-2012 10:00 AM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-24-2011 12:04 AM
Cutting tile on a diagonal kntry Building & Construction 7 09-09-2009 11:52 PM
cutting mosaic tile amakarevic Flooring 6 06-04-2008 05:02 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
