Cutting Through Tile Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 10:53 AM   #1
Rewards Points: 156
cutting through tile floor
So I need to cut a hole out of an already tiled floor to install a drain. What tool should I do to do this? I was thinking a dremel with a diamond blade would work, keeping the area wet. Any other suggestions?
Branden is offline   Reply With Quote
Old 12-01-2010, 11:40 AM   #2
KCB
there are holesaw blades available for all types of tile , different sizes as well.Available for high speed drills rotary tools etc...Thats what i would use .
KCB is offline   Reply With Quote
The Following User Says Thank You to KCB For This Useful Post:
Branden (12-01-2010)
Old 12-01-2010, 11:50 AM   #3
Rewards Points: 156
KCB, thanks for the reply. Problem is, I know hole saws can be pretty pricey and I doubt I'd be using it more than this one time.
Old 12-01-2010, 12:18 PM   #4
cutting tile
Hello, Branden, I've got a couple of ideas for you. If you hole doesn't need to be round, you could use a diamond tile blade on a grinder. It's possible that the drain would cover the hole. But, I'm guessing that it does need to be round, just thought I'd throw that out there. The Dremel option is good, and you are correct about the tile blade. Something else to look at is the Dremel Trio. it functions as a plunge saw and comes with the bits you need in the kit. With the Trio you should be able to cut your circle with no problem, it will cut through the sub floor and thin set too, just let the tool do the work; no need to force it.
I work at The Home Depot in Atlanta and I get asked this question all the time, and I always tell people to go to the Dremel website (www.dremel.com) to check out the versatility of the Trio.
I'm Ray the Hammer, good luck and keep me posted
thehammer01 is offline   Reply With Quote
The Following User Says Thank You to thehammer01 For This Useful Post:
Old 12-01-2010, 12:55 PM   #5
What kind of tile is it?
mrgins is offline   Reply With Quote
Old 12-01-2010, 02:12 PM   #6
Rewards Points: 156
Hammer, I need to cut a round hole. I already have a dremel (I think the first one that was ever made) and can get diamond studded blades for it, just not too sure how easy/hard it'll be to use. Dremel Trio looks like a cool tool, but really don't want to buy anything too expensive right now.
mrgins, it's ceramic.
Old 12-01-2010, 04:57 PM   #7
A Little Of Everything
Rewards Points: 1,356
This is what I've used to cut a lot of holes in tile. It's about $20 at Home Depot. I believe mine is a 1-3/8th. It has held up well and was worth the investment.
DrHicks is offline   Reply With Quote
Old 12-01-2010, 07:30 PM   #8
Maybe you can rent a big enough diamond hole blade?
JCW355 is offline   Reply With Quote
Old 12-01-2010, 08:59 PM   #9
DIY staff
Rewards Points: 7,174
If you go to a plumbing supply house you will be able to find a square drain---a round hole in existing tile is difficult without a hole saw.
Old 12-03-2010, 11:12 AM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
When I did my shower I purchased a diamond hole saw on ebay. I know it was a cheap one, but I only needed it once.
Old 12-03-2010, 12:01 PM   #11
tile cutting
Branden, 'tis I, The Hammer again. There is an option available for the Dremel that would make it work like a plunge saw. Check that out, it may work for you. You'll need to buy the tile bit separately, but it should do fine.
Good luck.
Hammer out
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 09:34 AM
Replacing Tile Floor in Shower banglenot Flooring 9 05-23-2011 10:05 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Radiant floor heat under 3x8 feet wide strip of tile - how to build up rest of floor? lazzlazz Flooring 2 03-31-2010 06:52 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
