Cutting Own Long Leaf Pine Flooring..... - Flooring - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 11:39 AM   #1
Cutting own long leaf pine flooring.....
I have the opportunity to cut and dry my own LLP boards for my house we're building. What size (L,W,T) should I cut them at and how should I plan for the install. I'm sure I will I have to butt them together when installed w/ no T&G...does this mean I will have to face nail them?
Need a little guidance here if anyone has any experience w/ this.
TIA.
PS, left out some important info, this is a raised floor home with 1 1/8" T&G subfloor, so the flooring can be installed directly on top of the vapor barrier, prob Tyvek
jjwalker is offline   Reply With Quote
Old 08-01-2010, 03:46 PM   #2
Rewards Points: 5,336
Never heard of flooring over Tyvek. Usually it's over rosen paper or felt paper.
Ron
Old 08-01-2010, 04:48 PM   #3
DIY staff
Rewards Points: 7,174
You didn't put your location into your profile so I will not be specific--
I suggest that you might find a local sawmill or a cutter with a portable mill---
many offer drying service and some can make the flooring for you ---tongue and groove,planed and ready to install.
Here are two links that will give you a start---Nelsonwoodworks.biz - Home
The Forestry Forum - Index
My suggestion as to thickness is 4/4 planed to 3/4--S4S tongue and grooved.
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 11:01 AM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 06:21 AM
Pine flooring CoryM Flooring 3 07-07-2007 10:02 PM
wide pine flooring restoration lgarbacz Flooring 1 09-28-2006 12:55 PM
Sealing southern pine flooring DMA Flooring 1 02-28-2006 09:37 AM
