Cutting Laminate With A Saber Saw? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-20-2008, 03:18 PM   #1
Rewards Points: 682
cutting laminate with a saber saw?
Is it possible to cut laminate pieces lengthwise with a saber saw without shredding the aluminum oxide layer too much? Maybe there is a blade that is specialized to do that work?
I would assume that a saber saw would be too rough, but if it could be done, one wouldn't have to buy a table saw. Also I think a saber saw would be good to make irregular cuts to make the laminate reasonably close to the wall without touching it.
darsunt is offline   Reply With Quote
Old 02-20-2008, 06:25 PM   #2
Custom Cabinet Maker
trim router, 1/8" bit, straight edge
skymaster is offline   Reply With Quote
Old 02-20-2008, 08:26 PM   #3
electrical contractor
Rewards Points: 150
are you talking about flooring?
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-21-2008, 01:00 PM   #4
Rewards Points: 682
Yes, laminate flooring. I have a chop saw so it is no problem cutting the pieces across the short side. I'm concerned about trimming the pieces lengthwise against the wall.
Old 02-21-2008, 04:55 PM   #5
Rewards Points: 150
You can chew them off as long as your covering it with baseboard or 1/4 round
mike costello is offline   Reply With Quote
Old 02-21-2008, 09:11 PM   #6
Rewards Points: 150
use a metal cutting blade in your sabre saw, and turn the workpiece upside down to minimize chipping, this method worked good for me. The cut is a little slower with the metal cutting blade but it is smoother.
Jimmy
Old 02-22-2008, 08:42 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I would suggest investing in a table saw. Even a cheap one for your project.
- Build Well -
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 08:07 AM
laminate floor vs subfloor 4 railing mount gdub Flooring 4 01-04-2008 03:42 PM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
