Cutting Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 12:02 PM   #1
jkk
Rewards Points: 233
Cutting laminate flooring
What type of blade and saw is best for cutting laminate? I have a chop saw but I've noticed dual-rail " flooring saws". Are they necessary?
jkk is offline   Reply With Quote
Old 07-04-2013, 04:34 PM   #2
Rewards Points: 13,450
Hope not, I've been cutting laminate for at least 10 years with just a compound miter saw.
It's suggest to use an 80 or 100 toothed blade, I've cut it with less without a problem.
Old 07-04-2013, 04:56 PM   #3
DIY staff
Rewards Points: 7,174
the material is murder on blades---I used to make a cutting box for a Skilsaw--Now I use the cheap 7 1/4" sliding chop saw from Lowes--Kobalt--works very well.
JetSwet (07-05-2013)
Old 07-06-2013, 08:51 AM   #4
I bought a 10" blade for my table saw and a 12" blade for my miter saw, brand is CMT "fine finsh" for laminate. The laminate material does not cut as well in my miter compared to the table saw. The table saw rips right thru the 12mm laminate effortlessly. Looking back, I could do without the second expensive blade for the miter. My miter saw is not a sliding type (which would help), just top down cutting angle. It cuts fine in the miter, but the table saw is seriously effortless. I bought the blade on amazon.
Even Further is offline   Reply With Quote
Old 07-06-2013, 09:30 AM   #5
Davejss's Avatar
Rewards Points: 740
I use my jig saw. I stay down on the floor. No getting up and going to the chop saw. All the cuts are hidden by molding so not much need for super precision. The jig saw cuts through quickly and its right there on the floor with me as I go along.
Davejss is offline   Reply With Quote
Old 07-06-2013, 12:28 PM   #6
MJ Force's Avatar
Rewards Points: 150
Originally Posted by Davejss
I use my jig saw.
I use a cordless jigsaw too. Medium wood blade. Cut from the bottom side of the board to prevent pulling or tearing of the finished side. Use a speed square to scribe the line as a guide. Very little mess and saves time and your knees.
MJ Force is offline   Reply With Quote
Old 07-07-2013, 12:28 PM   #7
Talking
+1, I've been a flooring installer in the uk for 25 years. Take 3 pieces of laminate and stagger them and then cut with a jigsaw.
midnightfox is offline   Reply With Quote
The Following User Says Thank You to midnightfox For This Useful Post:
oh'mike (07-07-2013)
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 09:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 07:34 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
